Competition Mode slower response than normal?
Almost like I have to step on the throttle harder. Anybody else feels this?I am trying to get used to using the competition mode for the track.
One theory I have is that in case anyone hits that button on the console by accident, then there is less chance of losing it on throttling, sort of like toning it down a bit. To me though, competitive mode should be "competitive" driving and it just doesn't make sense to me.
Please feel free to chime in.
As for your theory...someone would have to accidently hit the button repeatedly.
Again, I've never experienced any lack of throttle response in comp mode.
This was a recent HPDE at VIR with R compound tires, the OEM tires have much less grip IMO so turn off everything with caution.
I have been driving mine for 14 months and I have noticed that in comp mode there's like an ever so slight lag in the engine responce. Like you I thought it was only my car doing this. I've done some searches but could not come up with an answer. I had heard there was a software up grade for a so called 'Stall and Hesitation' issue. But when I asked my dealer about it they could not come up with anything from GM about this. Maybe someone can find out more additional information and post it here. If this up grade exists this might be the fix for this issue.
So it isn't just me. Thanks for everybody's feedback!Now I am lost! I have about a dozen track days under my belt and usu run intermediate/high intermediate with my boxster. This saturday will be my first track day with the vette. Do I leave everything on, traction off or comp mode...HELP!
Ted
Here's how it works......C5 and C6 Corvettes have an electronic throttle....On C5's there's a "throttle actuator controller' or "TAC MODULE" and C6's have the "TAC" module built into the ECM as one of the 3 internal processors.....
Due largely in part to the incredible performance of the lightning fast electronic throttle and the LSx series of engines incredible low end torque, the throttle has to be "curved" so that it isn't too responsive...#1) cause you could break parts and #2) cause you could EASILY spin the tires causing a VERY unsafe condition.
If you are driving a car with a CABLE throttle, the engine's response to the manual throttle cable or pedal is "linear" meaning that 5% throttle using your foot equals 5% throttle body opening and that 100% (floored) throttle is roughly equal to WOT or 100% throttle body opening. Hence they are about the same and more importantly, LINEAR.
Welcome to ELECTRONIC THROTTLE. When your foot is at 25% of the way into the throttle the engine's throttle blade is about 3.1% open!
and at 50% throttle of foot travel, the engine's throttle is about 15.1% open!
The throttle is especially curved in the "below 50%" area and dosen't begin to get more "natural or linear" till above that point. Below 50% it is horrendous which causes unwanted side effects with respect to how GM tuned the cars originally (especially with automatics).
Unfortunately, most tuners can't or don't address this. ALL of my LS1/LS6 tunes have corrected this problem while maintaining a smooth throttle transition.
The problem is that with LS2/LS3/LS7 controllers, NOBODY can fix it.....yet. Until now, I'm the only guy that has ever even seen it for the LS2 family of controllers. I was testing it for a time for one of the companies, but while I got it working....it also caused problems and was unreliable.TRUST ME THOUGH.....I'M RIDING THEM TO CONTINUE WORKING ON IT.
As an example....The 06 and later ZO6 (due to it's huge power) has a MUCH MORE SUBDUED throttle than LS2's of the same year and for all controllers and vehicles (believe this or not!) When you decide to "GET ON IT" with the car in "competitive mode" (thinking that you're "getting on it") the throttle response curve is DISGUSTINGLY more conservative than in normal mode....HOW STUPID IS THAT????
Trust me, I'm the "GM ELECTRONIC THROTTLE SCIENTIST" and have spent zillions of hours messing with the system... While I'm still at it....it will be a while before it's working.....it if happens.
Realize the disaster and troubles if "just once" a GM electronic throttle stuck open....For this reason there are dozens of redundant safety checks which have delayed the release of this very powerful tuning feature for LS2 family controllers.
Also realize that some of what you are feeling is also "torque management" if it's not turned off...
I'm on your side and I'm still at it... WE NEED THIS FEATURE...but, PLEASE be patient.
This has been a public service announcement from:
CHUCK COW
While I have you on topic... can you explain the LS3 e-gas torque management?
Recent Porsches with e-gas regulate torque to maintain constant speed for a given throttle pedal position. For instance, if one drives at 80MPH on a level road and all of a sudden the road goes uphill, the car will maintain the same speed as long as the right foot is steady - IOW no need to accelerate to maintain the same speed. I am not sure that the LS3 does that. Does it?
As to E-GAS...It's really a slick computer...but.......That's not something I'm aware of....So far, I haven't felt it or seen it in the computer anywhere.
Chuck CoW
