TPMS...Need help or advice
Just put some wheels on my car, and from what I see the tires are low. For some reason the TPMS light says that my tires are low on one side and high on the other. I am assuming that the installer put the sensors back in the wrong sides. My questions is this normal? And if so can they be reset? Thanks in advance
? It is possible the tire guy got them mixed up. Yes they can be reset with a scan tool, maybe your tire guy has one and should do it for no charge if he mixed em up. Dealer may have a scan tool also. The car has to be driven a certain # of miles to see any new pressure changes shown on the DIC. You might want to lower one tire and drive a few miles, and repeat to see if sensors are in correct corners. Lots more info here if you try a search.
http://forums.corvetteforum.com/show...highlight=tpms
