Two quick C6 Q's
1. I'm tall, 6'7" I've done a search on headroom, but not totally convinced when I hear comments like "I know a guy whose 6'6" and he fits OK." Any personal comments about headroom in the C6 coupe?
2. Gas mileage, I've heard accounts of high teens to mid twenties for all-around driving. My question, which has better real-world economy MN6 or AT6? I know, I know, the vette is a sports car and should be driven like one, YMMV, but I'm just curious to hear a few personal accounts.
Thanks.
Thanks.
Maybe, it's my driving habits -- I come from the old school of driving BMWs where it's best to keep the RPMs in the range of 2,500 and up -- and when I drive an MN6 or am using the paddles on my A6, I tend to shift at the higher points. Note--> If you never shift before 2,500 RPMs, you will never have a problem with CAGS.
But, the cold reality is that the A6 chooses its shift points to keep the RPMs in the 1,200 to 2,000 range in normal driving and this 1,000 RPM difference does have an impact on the MPGs. But then, if MPGs had been a big concern for me when buying the car, I would be driving a Prius.
At 6'7", there's a very good chance you won't fit at all.
I'm 6'3". My friend is also 6'3", but with a 3" shorter inseam. I fit comfortably in the car (but if I were any taller, it would be a problem). He can't fit without slouching. You need to sit in one and see for yourself.
Also check if the back of your head whacks the roll-hoop behind the seats. I've nearly knocked-out my tall friend under hard acceleration.
As far as mileage, I get 15 to 16 mpg per tank in my daily driver Z51 MN6. I have a short 15-mile roundtrip commute that is a mix of city streets and congested, slow and go, freeways. I tend to drive fairly conservatively, shifting around 2500 rpm and running steady around 1500 rpm.
The '06s also have some advantages over '07s: an off switch that takes effect right now (essential for any 400hp machine I'm getting into), an underhood lamp and a hatch handle (both victims of third-year cost-cutting), all the Z51 coolers promised by the brochure (secretly shortchanged in '07), low-bling sill plates, a steering wheel unsullied by the indignity of radio buttons (optional in '07), no garish two-tone seats with unsubtle Corvette logos (optional in '07), and of course the availability of that greatest of colors, Daytona Sunset Orange Metallic (no longer available in '07).
'07s do have ever-so-slightly-better-made wheels (Italian Speedlines), a bigger glovebox, and a significantly better warranty (for whatever that's worth, seeing as you have to take it in to a Chevy dealer for warranty work).
And of course, the roofs of '05s, '06s and early '07s tend to fly off, but that's covered forever under a recall campaign.
