Shift Knob
Old Apr 28, 2007 | 10:30 PM
Zoot Allures's Avatar
Zoot Allures
Default Shift ****
The shift **** on my '05 auto trans coupe is loose. It rotates about 1/8-1/4 " Has anyone had a similar problem and if so is it an easy fix ?
Old Apr 28, 2007 | 10:34 PM
hulksdaddy's Avatar
hulksdaddy
If you could just get that Ring back, should be an easy fix!
Old Apr 28, 2007 | 10:49 PM
Radical05's Avatar
Radical05
All it does is slide in a slot down the shifter shaft and a 'u' shaped spring clip keeps it in place. You would have to replace the **** I'm guessing as the nylon insert is worn. Mine was replaced by me with a Momo a while back as I never liked the square **** anyway.
Old Apr 28, 2007 | 10:55 PM
Zoot Allures
Thanks Radical, I'll give that a try because I can't find Frodo!
To Shift Knob
