differential fluid changed 2x
Old May 11, 2007 | 02:48 PM
Mel 2001's Avatar
Mel 2001
Default differential fluid changed 2x
13000 miles 06 A6 vert and rear end is yelling at me again for 3rd time. Going in next week for new clutch packs. Anyone know is they are using a better replacement material?
Old May 11, 2007 | 02:59 PM
teazr1's Avatar
teazr1
Don't know for sure but mine is getting new clutch packs on Monday. 05 MN6 with 18,000 miles.
Old May 11, 2007 | 04:12 PM
StLRick's Avatar
StLRick
St. Jude Donor '07
I just had mine done with 15900 miles on it for the second time and it will be a wait and see. The first time was 5k miles on it.
Old May 11, 2007 | 04:24 PM
calemasters's Avatar
calemasters
At one time (early 2006) the fibre clutch disc where going to be replaced with carbon cltuch disc. Not sure if that occured?
Old May 11, 2007 | 04:37 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
get back to me after the 5th time, along with the clutch pack and rear differential
Old May 11, 2007 | 09:38 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Before letting the dealer disassemble your car, try adding another bottle of GM friction modifier to your diff. (part number 1052358)
This made my rear silent after 2 drain and flushes failed to solve the problem.
And yes, my car still leaves 2 very black strips of rubber when doing a burn out.
Tom
Old May 11, 2007 | 09:53 PM
Vet's Avatar
Vet
Originally Posted by TCW
...And yes, my car still leaves 2 very black strips of rubber when doing a burn out. Tom
If this is truly a cure with no adverse side effects, I wonder why GM just doesn't do it. It makes sense that the extra friction modifier additive would help keep the clutches quiet, and apparently a lot of dealers had been simply dumping in extra additive anyway... even though not specificed by GM in the TSB. I'd think there would be a good reason that GM would not specify the use of extra additive... because it would be SO much cheaper and easier for them to go this route as opposed to changing clutch packs etc! If and when my differential noise comes back, I think I too will try adding a bit of extra additive after another flush.
Old May 11, 2007 | 11:45 PM
humvet's Avatar
humvet
Exactly! So what is the issue with these clutch packs? Are they defective? Are they subject to failure with too many burn outs? Why do some make noise and the majority don't? I don't understand this issue. Please someone advise.
Old May 12, 2007 | 01:04 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I've never had any problem with the differential on my 2005. As a matter of preventative maintenance I just changed the transmission fluid to Royal Purple. I planned to change the differential fluid to Royal Purple but now I'm wondering....should I leave well-enough alone? If it ain't broke....
Old May 12, 2007 | 01:47 AM
calemasters
According to the brand quality engineer, 2 bottles of the limited slip conditioner would decrease the effectivness of the limited slip clutches.
Old May 12, 2007 | 04:49 AM
lvjetboy's Avatar
lvjetboy
Maybe why slime has no place in the original design specs. A cheap way to cover up a design problem though.
Old May 12, 2007 | 07:29 PM
Mel 2001's Avatar
Mel 2001
I have an appointment Wednesday to replace defect. You would think they would fine a better material to fix this problem.
Old May 12, 2007 | 08:26 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old May 12, 2007 | 08:34 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Pulled this from the FAQ's
http://forums.corvetteforum.com/show....php?t=1249546
Mine just started doing it too.
Old May 13, 2007 | 12:58 PM
JJC1's Avatar
JJC1
Got a lot of chatter at 12k, dealer did the differntial change with 2 bottles of additive, sounds like new, will monitor closely that's for sure.
Old May 13, 2007 | 06:28 PM
TCW's Avatar
TCW
GM does a lot of things that don't make sense! That's why they are losing market share to the rice grinders.
Tom
Old May 13, 2007 | 06:39 PM
knkali's Avatar
knkali
2 bottles in mine so far so good
Old May 13, 2007 | 07:41 PM
kgelliott's Avatar
kgelliott
2 weeks and 2 days since mine was changed at dealer. All is quiet so far! Keeping my fingers crossed!
To differential fluid changed 2x
