Pipedream splashguards
Old May 18, 2007 | 11:12 PM
ROADKILL2007's Avatar
ROADKILL2007
Default Pipedream splashguards
For the front splash guards do you keep the base in the wheelwell put splashguard over the base and then put pin back in through splash guard or put splashguard up against wheelwell and put base and pin together through splashguard. Thanx
Old May 18, 2007 | 11:18 PM
Tom_Slick's Avatar
Tom_Slick
I pushed the base thru the splash guard and fender lining to line them up, then pushed the pin in and tapped it in with a mallet. Started at the top and worked my way down.
Old May 18, 2007 | 11:27 PM
RadarP3C's Avatar
RadarP3C
The website has a well illustrated instructions page for the install. The splash guard is directly against the wheelwell, then base and pin through the guard into the wheelwell. Very easy install.
Old May 18, 2007 | 11:28 PM
hulksdaddy's Avatar
hulksdaddy
MaxOctane's Avatar
MaxOctane
you had to use a mallet? All of mine go in no problem with just a firm push of my thumb...
Old May 18, 2007 | 11:36 PM
ROADKILL2007
thanks. got it now
To Pipedream splashguards
