Quality Control ?
Old May 31, 2007 | 05:52 PM
VF1000R's Avatar
VF1000R
Default Quality Control ?
Hmm, Just got my 2007 up on my lift .
Notice anything funny ?
http://i180.photobucket.com/albums/x...3smallbolt.jpg
And , there is NO insert for the bolt to go into.
Old May 31, 2007 | 05:54 PM
RED2008Z06's Avatar
RED2008Z06
pee hole?????
Old May 31, 2007 | 05:55 PM
Modshack's Avatar
Modshack
Guess you've never been to the factory huh?
Old May 31, 2007 | 05:56 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
lOOKS LIKE THE EXHAUST IS SCRAPED
VF1000R's Avatar
VF1000R
Or I can do It like this , now that I understand how to properly post a Pic.
Old May 31, 2007 | 05:57 PM
VF1000R's Avatar
VF1000R
Went Tuesday this week.
Old May 31, 2007 | 06:01 PM
VF1000R's Avatar
VF1000R
Oh , and Here's my signoff.
Old May 31, 2007 | 06:06 PM
C6Brian's Avatar
C6Brian
Looks like you bought a Friday car.
Old May 31, 2007 | 06:09 PM
Modshack's Avatar
Modshack
Last time I went, some gorilla was screwing on suspension pieces with a cigar in his mouth and a boom box on his shoulder. One missed bolt on the tunnel plate is no big deal!
Old May 31, 2007 | 06:10 PM
User 020720's Avatar
User 020720
Does it also have the 243/799 heads combination?
But seriously damnit now I have to crawl under my car and take a look.
Old May 31, 2007 | 06:14 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
at the end of the line, in the "test and qc area" , the guy who got in to start the car had a dangling cig in his mouth with an even lonhger ash (than the cig unburned). when he got out, the ash no longer existed but the cig was still in his mouth and hadn't been removed.
i wonder if he has a blanket soaked in......
Old May 31, 2007 | 06:16 PM
timd38's Avatar
timd38
I see it.
Old May 31, 2007 | 06:21 PM
Hells's Avatar
Hells
St. Jude Donor '08
As long as one of the guys working on the production line doesnt put a urine soaked blanket on the hood it should be ok.
Old May 31, 2007 | 06:31 PM
User 020720
Dude you beat me to it, too funny!
Old May 31, 2007 | 06:43 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Wow, that's different. Unfortunately you have just been introduced to the wonderful world of mass production and time constraints. The Corvette Assembly plant is just that, an assembly plant. They take a collection of parts from all over the globe and assemble them into a Corvette. Parts are "sampled" as they arrive using statistical sampling methods and assumptions are made about overall quality of the lot based on the results of those samples. The plant operates on a JIT basis and truckloads of parts come in daily. Congratulations, in NCRS circles you have a rare Corvette now that you have documented this as "as received" from the plant.
Even more sad is the fact that this was probably spotted on the line and passed as a "non-critical" defect. The absence of one bolt in the tunnel plate is not really a big deal in the performance of the car in 99.9% of all driving applications. I would imagine however that by the time it was spotted it may have been too late and the car would have needed a major tear-down to get to the mating part and replace it. It is likely that this was decided to be a minor defect and sent on its way rather than remake the entire car over it.
Paul
Old May 31, 2007 | 07:44 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Quality Control....where close counts!
Old May 31, 2007 | 07:49 PM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Paul
Can he get a bolt and screw it in? is it that easy. he has a lift so maybe he could pick up the 'slack' for the factory
To Quality Control ?
Old May 31, 2007 | 07:57 PM
keg's Avatar
keg
Hay look at the weight your saving. It should make your car the fastest factory stock machine around.
Old May 31, 2007 | 08:17 PM
OregonC6's Avatar
OregonC6
what do you expect for one hundred grand or so plus benefits and pension a year? You want a pickle on your burger at the fast food place and they make minimum wage.....there is generally a pickle on the burger cause if they miss it they will be fired.
But you can't fire these union people. Another thread recently showed a bell housing bolt backed nearly all the way out on a brand new vette....and off and on lots of other defects get through.
I have a background in QA and can tell you that missing tunnel bolts are not trivial 'cause they are so easy to spot. It sends a scary message that if they can miss something in plain sight what was missed that's difficult to see and inspect?
When you pay people at least four times what the prevailing wage rate is for similar or identical work, give them gold plated benefits, gold plated pension, and near complete freedom from being dismissed for poor work......what do you expect?
It's come to this. And from this it goes offshore. First the engine, then the transmission, perhaps the frame rails, then this and then that and it not only gets made much more inexpensively it comes back with much higher quality too. Why? Because the workers value their jobs and don't take them for granted.
just my opinions. y'all check your bell housing bolts y'hear?
Old May 31, 2007 | 08:27 PM
VET4LES's Avatar
VET4LES
Maybe it just the light but it looks like the underside has been painted. My floor boards look like the the one with the names and date.
