Passive Lock Feature
Old Jun 11, 2007 | 12:21 PM
jpeardm's Avatar
jpeardm
Originally Posted by Duck916
"Fob" is just a word for a piece attached as part of a key ring. It's not an abbreviation.
F.O.B. is also a shipping term, meaning "free on board."
and in medical records FOB = father of baby (wasn't me)
Old Jun 11, 2007 | 12:42 PM
Wingrider's Avatar
Wingrider
I use it all the time. As to the FOB issue, I keep it in my left pants pocket, and never take it out. Never a problem.
Old Jun 11, 2007 | 12:54 PM
shopdog's Avatar
shopdog
Originally Posted by keg
This is the same way I have mine programmed. I just wish that when you approched the car at night say within 10 feet or so that the lights would come on first before you grabbed the door switch.
To do that, the car would have to continuously query for a fob, and that would drain the battery. The way ours works, the car doesn't query for a fob until you do something that requires fob authorization, such as touch a door or hatch switch, or attempt to start the car. That way neither the car nor the fob are exhausting their batteries just on the off chance you might walk by.
Old Jun 11, 2007 | 02:18 PM
LSD 2005's Avatar
LSD 2005
Originally Posted by Zymurgy
I've used it since the day I picked up the car (daily driver for about 15 months now). Never had a problem and have never locked my fob in the car.
I personally like the horn 'toot' as confirmation that the car has locked. I shut the door and walk away. 8 seconds later, I get the confirmation 'toot'. If you don't want the horn to sound when you are at home, just press the lock button on the fob before the 8 seconds are up. This will lock the car and cancel the confirmation 'toot'.
If you leave the fob in the car and close the door, you will get 3 'toots' to let you know that you are trying to do something stupid. As noted in other posts, the fob will not be detected in the rear hatch area. So, don't throw your for in the back and then close the hatch. This is equivalent to throwing your keys in the trunk and shutting it in any other car.
Passive lock does not cause any battery drain.
I have used the Passive Lock System from day 1 with no problems.
Old Jun 11, 2007 | 02:28 PM
cadguymark's Avatar
cadguymark
F.O.B. originally was a notation on a purchace agreement or contract which meant Freight On Buyer to make sure both parties understood it was the buyer paying the shipping cost
I have not changed how the passive lock works from the factory, or maybe it was the museum who set it, don't know if they do it different. Works fine for me
Old Jun 11, 2007 | 04:07 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Originally Posted by JimTN
I've had 3 C6s and have done this on 8-10 occasions. The doors have never failed to lock for me.
Also, no, the passive locking does not use any current from the battery while it's locked.
It is very repeatable on my '07. I know because I have a fan I start with a switch in the garage on the passenger side. If I walk 3 feet forward of the passenger handle it locks. If I stop short it doesn't. What I need to experiment with is walking away from (as in walking around the back) and then return to the driver's door within the time it was supposed to lock and see if that will also confuse it.
Old Jun 11, 2007 | 04:55 PM
Kurmudjon's Avatar
Kurmudjon
From: I warm so easy so dance me loose -- it shines so bright the moon
Actually I think fob meant 'free on board' back in the day,which did spell out who was responsible for shipping charges. No matter, mine works fine!
Old Jun 11, 2007 | 05:01 PM
orca1946's Avatar
orca1946
Never had a problem with it
Old Jun 11, 2007 | 05:06 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by luckyj
How many C6 owners use the Passive Lock feature? Does a locked car put more of a drain on the battery than an unlocked car? Thanks.
Jim
I do. I always listen for the chirp to know it worked. I didn't use it on the C5 because where I kept my keys caused it to cycle sometimes and that was annoying at 0200!
Old Jun 11, 2007 | 05:20 PM
Arizona Z's Avatar
Arizona Z
Originally Posted by sabooher
None of my vehicles have ever had automatic locking so I don't use it on this car either out of habit.
I also am not fond of the possibility of the fob being locked inside the car.
Old Jun 11, 2007 | 06:48 PM
torquetube's Avatar
torquetube
I use the passive lock, and without the obnoxious horn reminder. A blink from the DRLs is enough.
A locked car doesn't draw more current. All it means for a C6 to be "locked" is that the door latch will not activate when the door button is pressed if no fob responds to the ping sent by the car at the same time. It's just a software state.
Old Jun 11, 2007 | 06:57 PM
torquetube's Avatar
torquetube
You've both got the acronym wrong, but the more-or-less the right definition.
F.O.B. stands for "freight on board." It designates that the charge for the item being shipped includes loading onto the shipper's truck, railroad car, etc., but not the shipping itself. This is especially important for heavy items -- if for example you're buying a milling machine, who's paying the rigger to load it?
Old Jun 11, 2007 | 06:59 PM
  #33
07c6vette's Avatar
07c6vette
i've set mine to auto lock flash only. the horn keeps bothering me specially if it's in the garage. so loud sometimes i get startled . also it will honk to remind you if you close the door while the key is inside the vehicle.
Old Jun 11, 2007 | 07:01 PM
  #34
Tom_Slick's Avatar
Tom_Slick
I could have sworn I read somewhere that the interior/ map lights can be programed to do that... Those s/b noticeable in the dark.
Old Jun 11, 2007 | 07:04 PM
  #35
torquetube's Avatar
torquetube
I feel there is no reason whatsoever that the keys or fob should be locked inside the car (flame suit on).
There are lots of possible reasons. For example, you're a woman, the fob is in your purse, you leave your purse in the car while you fetch the garbage cans from your driveway before leaving for work. Et cetera.
The danger with automation is thinking you're done when you've only covered 95% of the use cases. The devil's in that last 5%.
Old Jun 11, 2007 | 07:05 PM
  #36
Kurmudjon's Avatar
Kurmudjon
more fob info...but really who cares.
http://en.wikipedia.org/wiki/Free_On_Board
Old Jun 11, 2007 | 07:07 PM
  #37
streetpix's Avatar
streetpix
No, you have that wrong! FOB is defined in INCOTERMS 2000 as Free On Board. INCOTERMS is the universally accepted set of international terms of trade by the ICC, going back to 1936.
To Passive Lock Feature
Old Jun 11, 2007 | 07:18 PM
  #38
torquetube's Avatar
torquetube
Mea culpa. For whatever it's worth, a lot of shippers use the "freight on board" expansion.
The meaning, of course, is the same.
Old Jul 7, 2007 | 07:55 PM
  #39
4pipes's Avatar
4pipes
If you DON'T use passive lock, what happens if you leave the fob in the car? I'm used to taking the key out of the ignition and leaving it in the car in my garage.
Old Jul 7, 2007 | 08:25 PM
  #40
robl45's Avatar
robl45
On the C5, the passive lock seemed to work when you walked away, didn't seem to be a time limit. Is that not the case on the C6? I love the passive locking on the C5, one of the best features. I hope GM didn't botch up another good feature. Removing it on the later C5's was an especially good move.
