Passive Lock Feature
Old Jul 7, 2007 | 08:30 PM
  #41
Tom_Slick's Avatar
Tom_Slick
Originally Posted by 4pipes
If you DON'T use passive lock, what happens if you leave the fob in the car? I'm used to taking the key out of the ignition and leaving it in the car in my garage.
My horn beeps a few times as a reminder! I don't remember if I programed this through the D.I.C. or not... To my knowledge it doesn't drain your battery, it s/b OK. Consult your owners manual.
Old Jul 7, 2007 | 08:35 PM
  #42
4pipes's Avatar
4pipes
I've read the manual and no real explanations or warnings.
Old Jul 7, 2007 | 08:44 PM
  #43
Vette_DD's Avatar
Vette_DD
Nothing. However, the car's not locked, so anyone can open the door and use the fob in the car to start the engine and steal the car.
Old Jul 7, 2007 | 08:54 PM
  #44
SteveTurner's Avatar
SteveTurner
Originally Posted by Zymurgy
I've used it since the day I picked up the car (daily driver for about 15 months now). Never had a problem and have never locked my fob in the car.
I personally like the horn 'toot' as confirmation that the car has locked. I shut the door and walk away. 8 seconds later, I get the confirmation 'toot'. If you don't want the horn to sound when you are at home, just press the lock button on the fob before the 8 seconds are up. This will lock the car and cancel the confirmation 'toot'.
If you leave the fob in the car and close the door, you will get 3 'toots' to let you know that you are trying to do something stupid. As noted in other posts, the fob will not be detected in the rear hatch area. So, don't throw your for in the back and then close the hatch. This is equivalent to throwing your keys in the trunk and shutting it in any other car.
Passive lock does not cause any battery drain.
I love this feature.
Old Jul 7, 2007 | 09:09 PM
  #45
4pipes's Avatar
4pipes
Thanks. I only plan on doing this at my house and I'm not concerned about theft.
Old Jul 7, 2007 | 09:25 PM
  #46
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
The only problem I've had is that I sometimes forget to lock my other cars, 'cause those ones require some action to set the locks.
Love it
Old Jul 7, 2007 | 09:34 PM
  #47
shopdog's Avatar
shopdog
As long as you're home, gun in hand, continuously watching, the car is probably safe enough unlocked. But if you doze off, or leave home in another car, then your car is wide open to theft, literally gone in 60 seconds. BTW, what did you say your street address was again? I could use a parts car.
Old Jul 7, 2007 | 09:48 PM
  #48
4pipes's Avatar
4pipes
Old Jul 7, 2007 | 10:02 PM
  #49
keyplyr's Avatar
keyplyr
...As to the FOB issue, I keep it in my left pants pocket, and never take it out.
Is that a FOB in your pocket, or are you just disappointed to see me?
Old Jul 7, 2007 | 10:21 PM
  #50
calemasters's Avatar
calemasters
Originally Posted by luckyj
How many C6 owners use the Passive Lock feature? Does a locked car put more of a drain on the battery than an unlocked car? Thanks.
Jim
I use passive locking. Never had a dead battery. Sometimes car sets unused for 3 weeks.
Does a locked car put more of a drain on the battery than an unlocked car? No.
Old Jul 7, 2007 | 10:22 PM
  #51
Vette_DD's Avatar
Vette_DD
Sorry, it's not a FOB, since it's not an acronym. It's just a fob.
fob1 (fob), n.
1. a small pocket just below the waistline in trousers for a watch, keys, change, etc. Cf. watch pocket.
2. a short chain or ribbon, usually with a medallion or similar ornament, attached to a watch and worn hanging from a pocket.
3. the medallion or ornament itself.
Note definition no. 3.
Old Jul 7, 2007 | 10:53 PM
  #52
mewillis's Avatar
mewillis
Default passive locking
I wish I had it on all my cars
Old Jul 7, 2007 | 10:59 PM
  #53
gbgary's Avatar
gbgary
i use it with a honk. fob never leaves my pocket.
Old Jul 8, 2007 | 01:25 PM
  #54
MackIII's Avatar
MackIII
Default Got more fob questions
OK, on the fob thing, can someone tell me why is it that when I go to disable the alarm (pressing the fob) it only unlocks the driver side? Also, (while in the car) I have the DIC set to unlock both driver and passenger doors after the ignition is turned off but only the driver side does. I have to hit the unlock button on the door to unlock the passenger's door. I want it set up to unlock both when the ignition is turned off. Any ideas on both my issues?
Old Jul 8, 2007 | 02:02 PM
  #55
Vette_DD's Avatar
Vette_DD
The DIC programming for "Passive Door Unlock" is probably set for DRIVER instead of BOTH.
I'd check my DIC programming for "Auto Unlock" after you shut off the engine. You may have it set for DRIVER instead of BOTH.
Remember that you have 2 fobs and you may not have both fobs programmed the same. Maybe you're using one fob one time, the other fob the next time.
Old Jul 8, 2007 | 02:42 PM
  #56
Les-10's Avatar
Les-10
Bow-Tie Guy
Originally Posted by Wayne O
I have no doubt auto-locking is a reliable and convenient feature but I don't use it. I carry the fob, car key and a house key. I don't find it difficult to press a button to lock the car. I'm fairly reliable...I've never forgotten to lock the car (when needed) and I've never locked my 'keys' in the car.
No problem with battery drain...either way you go.
