The owner's manual in my '05 C6 vert suggests using "silicon grease applied with a clean cloth" to treat the rubber weather stripping in various locations of the car to resist cracking and further the life of the rubber (paraphrased.)
Neither 2 auto parts stores nor a marine supplies store have heard of "silicone grease." They offered many alternatives, however I though I'd ask here first. Anyone use this?
I use a brand called Versa Chem 100% Pure Silicone Grease. It comes in a little metal squeeze tube about 3 inches long. I purchased it at a local auto parts store....O'Reily Auto Parts. I have to believe that Auto Zone, Pep Boys, etc would all carry some brand of this. Don't rely on the clerks in the store. You have to find stuff yourself. Usually if I ask, they say NOPE, WE AIN"T GOT ER. Then I go find it myself. Look around where they have thread lock, silicone adhesive, gasket maker, etc.
I've scoured my local autozone for the stuff - with clerk's help and without. Not been able to find it, and yes, my scouring was centered around the threadlock and adhesives section.
That's it, thanks. However their minimum shipping charge is $7.99, so with the $10.99 for the 3 tubes of grease, that's $19.00 for less than an ounce of product.
I tried that once too, but the overspray bleeds onto surrounding paint and stays there forever. Silicone is one thing you do NOT want on your paint. I'll never use silicone spray again!
Spraying it onto the rag first did not get enough silicone on it to do anything, either.
You want dielectric grease, all auto stores carry it. It is used on electrical connections to prevent oxidation, also used on spark plug insulators to prevent spark plug boots from sticking. It is silicone grease.
Last I bought was in a 3 oz tube packaged by "Permatex" (Item 22058). Like OldVetter wrote, most parts places sell it
Autozone should have it because I bought some this past weekend. It's neutral and forms an excellent 02 block. Also lubricates but w/o any specific bulk. Wont' work for heavy loaded beraings, etc. Great for multiple plug blocks, relay contacts, slide contact switches, rubber lube, speedo cables. It completely stopped the creaking I was was getting from my glass top....
