Newbee question
Old Jul 2, 2007 | 07:05 PM
JLargo's Avatar
JLargo
Default Newbee question
This is my first Vette, so please cut me some slack. The drive train (M-6) seems to be awfully noisy taking off in first and cruising in general. Is this normal with the Vettes or do I need to be concerned?
Old Jul 2, 2007 | 07:16 PM
EdCalVette's Avatar
EdCalVette
St. Jude Donor '09
What year is your C6 and how many miles ???
Mine is six months old, been tracked four times and auto crossed once, 12300 mi, and it is very smooth and quiet,
VET4LES's Avatar
VET4LES
It's normal and as you learn to drive it you will improve your shifting and clutch skills which will help.
Old Jul 2, 2007 | 07:25 PM
Wayne O's Avatar
Wayne O
CF Senior Member
It's difficult to know without hearing it but my manual shift doesn't make any excessive noise that I'm aware of. If you're concerned about it, take it to the dealership for an evaluation.
Old Jul 2, 2007 | 08:13 PM
JLargo's Avatar
JLargo
2007 with only 100 miles. When I first let the clutch out it seems a little noisy until the rpms pick up. I am not hearing any particular noise, it's just that the drivetrain seems a little noisy. It is probably normal and something that I am not use to since the Vette is small car and the seats seem to built around the drivetrain.
Old Jul 3, 2007 | 12:00 PM
JFFVETTE's Avatar
JFFVETTE
My 06 also makes a little noise at low RPM's when releasing the clutch in first. It doesn't do it all the time, and I've only got 1400 miles on it. I think it is normal.
Have fun with the MN6!
Old Jul 3, 2007 | 01:09 PM
User 020720's Avatar
User 020720
1400, don't get out much?
Old Jul 3, 2007 | 02:01 PM
redrokit8's Avatar
redrokit8
Default Noisy
I think it all depends on where you came from before your C6. If you were driving a so called luxury performance car you could be used to a isolated engine & drivetrain. Also were you driving a manual shift or auto? That right there requires an adjustment phase.
Try slipping the clutch a little more from dead stop and a little more throttle. You could very well be stressing the drivetrain by being too conservative.
Being involved in the car business, I can tell you there is definitely an adjustment period to becoming part of your car and not just a driver.
If all else fails-that's what warranties are for!
Old Jul 3, 2007 | 03:06 PM
JLargo's Avatar
JLargo
I think you are right on. I came from an SRT-8 Charger with the 5 speed auto. I believe I might be bogging it a little by not giving it enough gas like you mentioned as well. Thanks for the input.
Old Jul 3, 2007 | 03:24 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Jul 3, 2007 | 04:15 PM
JJC5's Avatar
JJC5
I think what you might be talking about is the "ratteling" noise that you hear just as the clutch is almost fully engaged as you are starting from a dead stop in 1st or even from a roll in a higher gear. What I've been told is it's the clutch making that noise and is completely normal.
Old Jul 3, 2007 | 04:56 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
Old Jul 3, 2007 | 04:59 PM
RED2008Z06's Avatar
RED2008Z06
enjoy the new ride..............
Old Jul 3, 2007 | 10:13 PM
User 020720
Originally Posted by JFTaylor
Is that Natalie Portman? Man she is hawt!
I'd toss her the 'keys' to my ride anyday.
Old Jul 3, 2007 | 10:19 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
What she said and what he said!
To Newbee question
