HP Question
Old Jul 8, 2007 | 11:06 AM
Hebstar11's Avatar
Hebstar11
Default HP Question
I know the engine is 400 HP. How much HP do the 05-07's have at the rear wheels?
Old Jul 8, 2007 | 11:12 AM
jschindler's Avatar
jschindler
340-350 for a manual transmission, about 15 less for an automatic. Keep in mind that there are a lot of variances in different dynos.
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Yet another dyno thread since those numbers came out from LGM on the '08.
If you search this forum, the following numbers are the ones you will typically find reported for the pre '08 C6 from the Dynojet dyno.
340-355 for the manuals
325-335 for the automatics.
The above are rough numbers, some examples have come in at a couple HP more.
Old Jul 8, 2007 | 11:13 AM
Vette_DD's Avatar
Vette_DD
Supposedly, about 326 for an automatic, about 340 for a manual tranny.
Old Jul 8, 2007 | 11:37 AM
Wayne O's Avatar
Wayne O
CF Senior Member
The nice thing is you can change the RWHP number.
Old Jul 8, 2007 | 12:04 PM
AFVETTE's Avatar
AFVETTE
And as has been the practice since the dawn of time, if you don't like your dyno numbers, find another dyno.
Tom
Old Jul 8, 2007 | 05:03 PM
MNVette's Avatar
MNVette
Different dyno's will produce different results. Plus, the weather on the day you have the run taken will play havoc with your results.
To determine rwhp, take the crank hp and multiply by 82% (accounts for the drain to the rear wheels):
crank hp x 0.82 = rwhp
This math works on a "normal" day, with normal temps and humidity.
That would equate to 328 rwhp on a stock C6. The tranny type also will influence your final number, but not by a lot (about 1-2%).
For example, Doug Rippie did a dyno for me one day, and the next day, the numbers went up 25 rwhp, mostly because it was slightly cooler and more dry outside.
It's like getting your house appraised - you can find an appraiser that will say just about anything you'd like.
Old Jul 9, 2007 | 08:35 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
My 07 dyno'd at 353 rwhp stock. 6-speed.
Old Jul 9, 2007 | 08:40 AM
johnodrake's Avatar
johnodrake
Moderator
Mine had 354 bone stock and 364 with a tune.
Old Jul 9, 2007 | 10:08 AM
Modshack's Avatar
Modshack
Tom
Yup......
Old Jul 9, 2007 | 12:07 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
It's not as precise as one would think. #s vary with air temp, humidity, Type dyno, and dyno operator.
Old Jul 9, 2007 | 12:23 PM
steppindown's Avatar
steppindown
Default Why the difference?
Probably a stupid question, but why are the rwhp #'s higher for the manual trans.?
To HP Question
