On my 3rd Roof
Old Jul 9, 2007 | 10:14 PM
blkc6z51's Avatar
blkc6z51
Default On my 3rd Roof
Roof #1 lasted one year, #2 lasted one year, now on my 3rd.
Went into dealer today to order the new one hope this replacement
roof is the SMC.
Old Jul 9, 2007 | 11:19 PM
Purdue's Avatar
Purdue
Your new roof will be a SMC....hopefully everything turns out OK.
Old Jul 10, 2007 | 12:15 AM
Zymurgy's Avatar
Zymurgy
Moderator
Only SMC roofs are available. I have not seen any reports of problems with the SMC roofs. You should be OK once you get the new roof.
Old Jul 10, 2007 | 12:18 AM
Wayne O's Avatar
Wayne O
CF Senior Member
You "...hope this replacement roof is the SMC..." I'd insist on it...vigorously!
Old Jul 10, 2007 | 01:14 AM
achilds's Avatar
achilds
roof is the SMC.
In CA I think if you get the car repaired for the same issue three times you can go for a lemon law claim.
Old Jul 10, 2007 | 06:19 AM
par34n5's Avatar
par34n5
St. Jude Donor '06
Default whats a SMC
roof is the SMC.
??what is a SMC
Old Jul 10, 2007 | 06:27 AM
HIRISC's Avatar
HIRISC
St. Jude Donor '06
I thought that too, but it appears that the lemon law kicks in after four times
http://autopedia.com/html/LemonLaw/CA_lemonlaw2.html
blkc6z51 - GL with your repair.
Old Jul 10, 2007 | 06:37 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The SMC top should do the trick. The others were just band-aids.
Old Jul 10, 2007 | 06:43 AM
talon90's Avatar
talon90
NCM Ambassador
Originally Posted by par34n5
??what is a SMC
SMC is sheet molding compound, a fiber glass reinforced thermoset compound in sheet form. The C5 roof panels were made of SMC. They switched the C6 panel initially to a polycarbonate to save weight (~3 lbs.). Differences of thermal expansion of the polycarbonate and the frame caused the adhesive to be put in shear during periods of high temperature which caused the panel to fail and delaminate. In August of 2006 for the 2007 model year cars the assembly plant finally was able to switch the manufacturing process back to SMC.
Paul
Old Jul 10, 2007 | 08:55 AM
MADMAX1's Avatar
MADMAX1
I'm also on my 3rd top..Hope this one holds together..
Old Jul 10, 2007 | 09:53 AM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
I have never had aproblem with my SMC
Old Jul 10, 2007 | 09:55 AM
Dan Dlabay's Avatar
Dan Dlabay
Had mine replaced with the SMC roof. No problems since.
To On my 3rd Roof
