2005 C6 Won't Start
Old Jul 12, 2007 | 09:44 AM
miami*Vette's Avatar
miami*Vette
Default 2005 C6 Won't Start
My Vette was working well and later in the same day, the car would not start. I replaced the battery just to trouble shoot if not enough cranking amps, checked all fuses, inspected all connections and nothing. The car just trgiggers rapidly when button is activated, but no ignition. The vehicle only has 13,000 miles.
Has anybody experience this problem and what was the solution.
Car is being picked up and to the dealership. I would like to know before hand and to be educated once I'm there.
Old Jul 12, 2007 | 09:51 AM
not08crmanymore's Avatar
not08crmanymore
more info is needed such as is the car auto or stick???DBS only hits 6spds from what I hear.That is DEAD BATTERY SYNDROME,that's affected many 05's.You have clicks,so it may not be that,and it's not the starter since you have clicks,so,maybe the cellonoid is bad.Open the hood and give it a whack,sometimes that works on a cellonoid.(If it;s still located under the hood!I'm pulling my brain info on cellonoid location from the 70's and 80's! )
Old Jul 12, 2007 | 09:52 AM
beaversstonehaven's Avatar
beaversstonehaven
I have no idea what the problem could be but please post back on the Forum when you find out what the problem was. Good Luck.
Old Jul 12, 2007 | 10:18 AM
70454's Avatar
70454
I had a NO FOB DETECTED message the other day when I entered the car with the fob in my left side cargo shorts pocket. I got an insane amount of relay clicking which came from the center dash speaker area (below the rearview on the dash). I got out, got back in, put the fob in the cupholder and she fired right up.
Old Jul 12, 2007 | 10:27 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Like Jess said we need more info on your car! example auto or manual
It COULD be a safety switch.
If a manual try pumping the clutch up and down while pushing start button.
If auto try moving the stick between nutral and park while pushing start button.
Old Jul 12, 2007 | 08:49 PM
miami*Vette
Sorry should have been more specific. The car is Manual and turns out to be the Fuel Pump.
Thanks for your reply.
Old Jul 12, 2007 | 08:52 PM
miami*Vette
Default 2005 Manual C6 Won't Start
Old Jul 12, 2007 | 08:55 PM
miami*Vette
Default 2005 C6 Won't Start Findings
Old Jul 13, 2007 | 10:38 AM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
shove fob in glove box slot to stop insane clicking noise/no start....fyi
To 2005 C6 Won't Start
