Buzzing from instrument cluster.
Old Jul 15, 2007 | 12:48 PM
JLargo's Avatar
JLargo
Default Buzzing from instrument cluster.
With the windows up and everything off except the car running I am hearing a slight buzzing from the instrument cluster. It sounds like an electrical type buzz. Has anyone else noticed this noise? This is my first Vette, so I am not sure if this is normal or not.
Old Feb 26, 2013 | 06:47 PM
REDRED's Avatar
REDRED
Did you ever get this resolved? My 2006 does the same..
Old Feb 26, 2013 | 06:50 PM
JChastain's Avatar
JChastain
Look at the windshield wiper black plastic cowling. If the plastic has raised up off the glass as in whorping, that's your culprit. The wind gets underneath the plastic making it buzz against the glass. Put a bead of black silicone behind the plastic between the glass and let it dry. Should fix the noise.
Old Feb 26, 2013 | 07:25 PM
REDRED's Avatar
REDRED
I don't think it was the wind. I wasn't moving and the noise stops when you turn the engine off.. Reminded me of a fluoresent bulb ballast buzz sound.
Old Feb 26, 2013 | 07:29 PM
REDRED's Avatar
REDRED
Actually, just found this:
beav626
It could be your ambient Temperature sensor. Right next to your start button. There is a little fan in there that sucks air through thesensor than can go bad. Mine was buzzing and I had it replaced and it is quiet again.The sensor is $70-$90 from parts taxi and waaaay easy to install. Very easy you just pop that plastic puiece off witha butter knife wrapped in a towel and inscrew the sensor, then unplug it and do the opposite. to install
Old Feb 26, 2013 | 07:59 PM
NCorvette's Avatar
NCorvette
Do you have a part number?
Old Feb 26, 2013 | 08:29 PM
EVRose's Avatar
EVRose
beav626
Thats exactly what it is. If its not seated in the plastic clips properly it will buzz too.
Old Feb 26, 2013 | 09:29 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our factory Nav often makes a slight buzzing sound for the first few minutes. Goes away by itself.
Old Feb 26, 2013 | 09:35 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Feb 26, 2013 | 09:37 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/foru...s-or-more.html
To Buzzing from instrument cluster.
