2005 Dbs
Old Jul 18, 2007 | 12:46 AM
Brian Fisher's Avatar
Brian Fisher
Default 2005 Dbs
Got hit by the DBS again on my 2005 MN6, must have been in 5th gear, I thought it was in reverse.
What is the recommended procedure to charge the battery?
3rd time since 9/06 when I got the car. I am getting pretty tired of this.
Brian
Old Jul 18, 2007 | 01:41 AM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Have you had the BCM reflash done at the dealer that addresses battery rundown?
They car chimes if you are not in reverse on shutdown. Did it?
Was the steering column locked when you got in the car after the battery was dead? If so it was in reverse.
Your battery is likely BAD now that it has been drained to zero a few times. Just one time significantly hurts the battery's lifespan.
I know, I have an 05.
Replace the battery and have the Dealer do the BCM reflash and you should be good from there on in.
PIC4188 is the document for the bcm reflash. Search the forum for it.
Hope this info helps!
Old Jul 18, 2007 | 06:15 AM
footba4672's Avatar
footba4672
Do all that and also get a "priority start". It is a must on any 05 MN6
Old Jul 18, 2007 | 09:01 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Brian
If it was left in 5 gear its not DBS its operator goof up! If you do have REAL DBS get it to dealer and get the flash done. Bring in the number of the procedure needed from the post above. (A lot of these dealers do not have a clue and will do a door flash, GIVE THEM THE NUMBER YOU NEED) (Long story there, but an unfortunate fact)
I "had" a DBS car (4 episodes). To charge; I just hooked up a 12 amp charger and let it do its thing. It lowers the charge rate as the battery is coming up to full power
I had the 4 mentioned DBS attacks and the battery still checked out ok at the dealers (how I do not know)! I got rid of the car with the original battery still in it.(a week ago)
I do believe the flash fixed the car FINELY; I did not get rid of car because of DBS problems.
Old Jul 18, 2007 | 09:08 AM
not08crmanymore's Avatar
not08crmanymore
BATTERY TENDER works too.The worst it's ever been on my 05 is once I caught it when there wasn't enough power to start the car but everything else worked.I jumped it,drove it,and hooked up the battery tender.All is well since then,still w/original battery.
Old Jul 18, 2007 | 09:42 AM
MNVette's Avatar
MNVette
There is no way to properly charge a battery once it has been completely drained due to DBS. The battery is shot. Take the car to the dealer, demand the reflash, and demand a new battery.
I don't care what ridiculous procedure GM came up with as a band-aid to address DBS, the fact is that this should NOT be happening. You should not need to attach a Priority Start or tender to the battery just because the car sits for a couple of days. If it were 2 months, I could see the necessity, but not for a shorter period of time.
Get the reflash and a new battery.
Old Jul 18, 2007 | 10:14 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Self-inflicted battery drain does not constitute DBS (although it sounds like there was some prior history with the issue).
Have the battery checked...replace if needed and have the reflash performed at the dealership if it hasn't been done.
Not mine....so far. I've never had any issues....2+ years and going strong on the original battery. I do, however, expect to replace the battery at some point soon. My experience is that batteries last about 2-3 years.
Old Jul 18, 2007 | 03:24 PM
Flareside's Avatar
Flareside
Same here, it's certainly not a necessity. 05 MN6 that's never had an issue (knock, knock).
How did you leave it in 5th at shutdown? My car won't turn off if you don't put it in reverse. Chimes go off when the engine stops, etc.
Old Jul 18, 2007 | 03:37 PM
Modshack's Avatar
Modshack
Mike is right. A completely discharged wet cell will never be the same again. Given the shaky history of OEM batteries, you'll probably face this again even after a flash. Check the battery voltage after sitting all night and after it's been fully charged on a charger the day before (driving the car won't do it). If the voltage is below 12.2 volts, the battery is only able to hold 50% of it's original charge. Time for a new one. your dealer will probably be in denial about this whole thing though..
Old Jul 18, 2007 | 03:52 PM
SpdWhite's Avatar
SpdWhite
With all of the above except a Priority Start. Shouldn't need to put a "band aid" on a $60K car.
I have had the re-flash and a new battery (third one) and so far so good. I have left the car for up to 2 weeks and it started up no problem.
Old Jul 18, 2007 | 04:29 PM
woodshark's Avatar
woodshark
I have an o5' with 10000 mi. and no problem at all. I read about this DBS on this site and asked my dealer about it. The service writer said he had never heard of such a thing, was he lying , or just a moron?
Old Jul 18, 2007 | 04:51 PM
6spdC6's Avatar
6spdC6
Possibly both!
IS that dealership a real small operation way out in the boonies that hardley ever sells a Vette?
Old Jul 18, 2007 | 05:23 PM
DP Dave's Avatar
DP Dave
After 3 DBS episodes I had the software "reflash" and no more problems (fingers still crossed).
Old Jul 18, 2007 | 05:53 PM
bunk22's Avatar
bunk22
My battery died after a year so I bought a yellow Optima. It lasted 8 months but at least I was able to recharge it. Didn't want a reflash since I've got my custom tune in there. So I opted for a battery charger. My 50K car (when new) gets to pull in the garage and have a charger plugged into the lighter so it will continue running :o
Old Jul 18, 2007 | 06:20 PM
weathermaker's Avatar
weathermaker
I've had mine for 21/2 years with no problem. I make sure it's in reverse, undo my seat belt , lift the steering wheel up, and THEN open the door. I think the 4-5 seconds it takes helps everything time to do it's thing.
Old Jul 18, 2007 | 08:14 PM
St. Jude Donor '13
The reflash doesnt wash out custom tunes. Its only for the BCM not the ECM.
Old Jul 19, 2007 | 12:00 AM
Jbal's Avatar
Jbal
Brian;
Last September, new battery, did the re-flash, & all is well! Other than the earlier DBS issue, my 05' has been Perfect!
Best of Luck!
To 2005 Dbs
Old Jul 19, 2007 | 12:05 AM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
It is not a must, I have had my 2005 over 2 years and 30,000 miles without any of this DBS you guys are talking about.
I must have the only "good one"
Old Jul 19, 2007 | 09:07 AM
6spdC6's Avatar
6spdC6
I did all that you say and still had 4 DBS attacks. I also made sure radio,AC/heater was turned off, turned steering wheel to lock position. Wait by car to make sure all lights go off. Fob is stowed nowhere near the car, You name it I did it. Some cars have it MOST do not. Lets see what happens as the cars and batteries age.
Your just lucky, (most cars were), but if you have DBS it appears nothing YOU do will prevent it. The reflash (for those that have it appears to work.)
Old Jul 19, 2007 | 01:52 PM
carjon's Avatar
carjon
Have an 05 MN6 - had no DBS for 8 months - put in priority start. Priority saved me probably 8 times over next 16 months. Battery finally wouldn't hold a charge. Dealer replaced the battery and did the re-flash. So far so good.
Probably my only real concern about this car is whether it will start when I get in it. I need to put the Priority back in but I'm too busy enjoying the car.
Get a new battery and the flash.
