Hot tunnel area
Old 08-15-2007, 06:20 AM
  #41
WHT
WHT's Avatar
Originally Posted by carpe dm
The plate will HOLD IN THE HEAT, not help abate it. Insulation of some sort is the answer.
As you say, insulation is important and most vender plates do provide insulation. However, even the stock plate without insulation reduces the heat entering the floor (since much of the heat is transmitted by thermal radiation and not convection or conduction). Plate + insulation is the best solution.
Heat is coming from the exhaust under the plate. Most vender plates have a ceramic coating or outer insulated layer and they will reflect and reduce the exhaust heat entering the floor. Some plates are stainless steel which does not conduct heat as well as the stock plate and reflects some thermal radiation. And, you always have some air flow between the plate and torque tube when the car is moving which reduces trapped heat.
Old 08-20-2007, 06:54 AM
  #42
AutoCutter
AutoCutter's Avatar
I don't know if I have been sleeping under a rock and didn't know this, but when I went to install the heat blanket, I noticed the 08' NPP exhaust uses an X-Pipe rather than the H-Pipe my 05' had-is this new
Old 08-20-2007, 06:56 AM
  #43
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yes, all of the 2008 cars now have an X-pipe in place of the old H-pipe.
Old 08-20-2007, 10:14 AM
  #44
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,838 Likes on 2,076 Posts
2015 C7 of the Year Finalist
Simple...
Top down, riding in the evening with wife in the passenger seat and she asked....
"Is the heater on?"
Tunnel heat caught her attention (already had my attention).
I installed the EE insulated plate. Problem solved.
I dun need no steeenkin engineeer to call my attention to an issue. The wife did it with 4 words.
So, Momma is happy. That makes me happy. We both are cooler. I got to do an easy mod while laying on my back.
Elmer
Old 08-21-2007, 04:30 PM
  #45
Steve R
Steve R's Avatar
I installed the tunnel abs from Elite Engineering this past weekend and it fixed the excessive heat in the tunnel! Very good product,excellent service Now when the wheels come up in second, they come up equally.
Old 08-21-2007, 06:15 PM
  #46
L.A.P.D.
Supporting Vendor
L.A.P.D.'s Avatar
St. Jude Donor '03-'04-'05-'06
Guys,
Either one of our plates will help cut down heat a lot.
Both 1/4" and 3/8" are on MAJOR DISCOUNT RIGHT NOW!
Here are the links so you can place orders:
Click here to place an order for a 1/4" tunnel plate at our ALL TIME LOW PRICE of: $164.95 SHIPPED PRICE!!!:
http://www.thelapd.com/Merchant2/mer...e_Code=thelapd
Click here to place an order for a 3/8" tunnel plate at our ALL TIME LOW PRICE of: $214.95 SHIPPED PRICE!!!:
Thanks!
Shawn
Old 08-21-2007, 06:34 PM
  #47
JayO
JayO's Avatar
Would it make sense to go the belt and suspenders approach with a insulated plate and heat blanket?
Old 08-21-2007, 07:20 PM
  #48
mitchm11741
mitchm11741's Avatar
Originally Posted by PeterSG
After several Vettes over 40+ years I can say yes, it gets warm in the console / tunnel area on hot days.
The heat is not excessive. Just don't put food in the console and all will be OK....
You can always use the heat to make grilled cheese sandwiches when you are stuck in traffic ... just kidding. It does not get all that hot. Heck, in the winter up north, you might actually like the heat.
Old 08-21-2007, 07:33 PM
  #49
PaBlueCoupe
PaBlueCoupe's Avatar
St. Jude Donor '06-'07-'09
I installed the Elite Engineering SS plate with Thermal Abs directly on top of the OEM heat shield. (which is obviously there to hold in heat. )
IMHO it works as advertised----Cooler & Stiffer
Old 08-24-2007, 02:24 PM
  #50
john351
john351's Avatar
Installed the E.E. 1/4 tunnel plate with the thermal ABS "blanket". Not sure if I notice any structural stiffening although haven't been to the Nurburgring to test it, but I definitely notice a reduction in temps in the console area!
Old 08-24-2007, 04:14 PM
  #51
dtwalkerfl
dtwalkerfl's Avatar
Where did you get the Thermal Abs? I just got a 3/8" ceramic coated plate from LAPD but looked at the Thermal Blanket from LG and got instant sticker shock! $419 for a thermal blanket? Seems a little outrageous compared to $214 for a 3/8" thick ceramic coated aluminum plate.
Old 08-24-2007, 05:46 PM
  #52
orca1946
orca1946's Avatar
Warm yes - hot no. If you have the AC on you won't notice . Think of it as a HOT CAR & people will assume it's OK
Old 08-24-2007, 05:55 PM
  #53
zbrett
zbrett's Avatar
I have a vert with an Elite Tunnel Plate and I did notice that it stiffened up the chassis a bit. I find the heat coming off the firewall to be more of an issue on hot days than any heat coming up through the console.
Originally Posted by rsimoes
Is there ANY improvement on making the car stiffer? (especially in a convertible) Or is that also questionable?
Old 08-24-2007, 06:23 PM
  #54
heisnuts
heisnuts's Avatar
The warmth never bothers me because the only items I keep in the center console are papers and sunglasses. I never really have drinks in the car when driving so the only thing in the cup holder is the cell phone (a great cell phone holder BTW). Yes, the phone and glasses get warm on long drives, but nothing close to hot where it would be uncomfortable to hold after sitting there for awhile.
Now, if you plan on keeping cold drinks in the cup holder or items in the center console that need to stay cool, it will be a problem.
Old 08-24-2007, 10:33 PM
  #55
DAYCRZ
DAYCRZ's Avatar
Originally Posted by talon90
The factory tunnel plate while better than nothing is little more than stamped sheet metal (steel). As I recall it is less than .125" thick and a good conductor of heat. The aftermarket tunnel plates are made from aluminum to prevent too much added weight but are at a minimum .250" and many to most are ceramic coated to reduce the amount of heat that is conducted.
On the 08 I can tell you it is not steel it is 3/16 aluminum and there is also some insulation installed above the tunnel plate, I don't know if earlier C6 cars have that or not but I saw the insulation and tunnel plate installed on mine Tues during the build
Dan
Old 08-31-2007, 10:24 PM
  #56
robl45
robl45's Avatar
I think most guys are commenting on the 05-07 cars. I can tell you for a fact that on the 08, the tunnel is hot. The center console space under the armrest does not get warm, it gets hot. The center console armrest does not get warm from the sun, I mean it could, but it is warming up from the heat being generated undernieth. Leave a drink in the cupholder and it will be warm fairly quicky as the cupholders get hot. You guys don't want to believe it? Take the center console out as I did this week and drive without it. Put your hand on the bare metal and see how long you want to leave it there.
Its not the end of the world for sure. If you aren't driving 300 miles each day, its not the biggest deal, just a nuisance. The rear hatches heat up uncomfortably as well.
Old 09-03-2007, 07:20 PM
  #57
rt66cat
rt66cat's Avatar
Default Easy exhaust heat fix
I wrapped my exhaust system with header wrap, 19000 miles on my 07
no heat on sides , some inside console, much cooler.
To Hot tunnel area
Old 09-03-2007, 07:43 PM
  #58
corvette05
corvette05's Avatar
Default tunnel heat solved
i have a z51...it comes with an oil cooler...thats exactly why i got the pkg....tunnel heat not an issue!
Old 09-03-2007, 07:50 PM
  #59
robl45
robl45's Avatar
What does this have to do with this thread? I have an oil cooler too and a roasting tunnel, not sure I understand.
Old 09-03-2007, 08:45 PM
  #60
V Vette
V Vette's Avatar
This is an on going issue from years past to date and SHAME on GM for not fixing this. Who do we need to contact???
Quick Reply: Hot tunnel area
