Tire Pressure sensor accuracy
Old Aug 15, 2007 | 11:56 AM
double eagle's Avatar
double eagle
Originally Posted by Buffy
There've been a couple of reports of this. The TPMS sensors are single-ported; they are absolute pressure sensors. Most gauges are relative pressure sensors - that is, they measure pressure relative to the ambient. As atmospheric pressure decreases with altitude (around 1 PSI per 1800 feet, as I recall) it makes sense that you'd read around 2 PSI lower if you moved from, say, 1000 feet in VA to, 4000 feet in C0.
Its been claimed that the BCM is supposed to compensate for this, by reading local atmospheric pressure via the MAP (Manifold Absolute Pressure) sensor before startup, but that feature doesn't seem to work.
Thanks for the info - will remember the psi difference when reading the DIC. FWIW, altitude in VA was 97', in CO it's 8500'.
Old Aug 15, 2007 | 11:57 AM
torquetube's Avatar
torquetube
The 44 PSI maximum is cold pressure, there's plenty of room there for normal increases due to warming. My tires stabilize at about 25-30 degrees F above ambient temp with normal driving, usually a 2 PSI pressure increase.
I normally run 36 PSI in front, adjusted to 10 degrees F above the normal seasonal low (75 for summer around here) and have only had the 42 PSI high pressure alert come on once - that being in 100 degree heat.
Still, the high pressure warning is sort of annoying, as (1) its only valid for the stock GY tires (my PS2s are rated 51 PSI max) and (2) it doesn't take heat into account. Anyone know how to change that?
These tire pressures seem rather on the high side. With cold pressure over about 33psi, my old Supercars started tramlining badly and visibly wore the tire centers in only a thousand miles or so.
I haven't tried the PS2s. You like what they're doing at 42psi?
Old Aug 15, 2007 | 02:01 PM
Buffy's Avatar
Buffy
The PS2s do seem to like a little more pressure than the GY Supercars. I'm running 36 front / 33 rear cold, which puts me around 38 - 40 front / 35-37 rear hot. Best stick seems to be pretty close to those figures, about 38 - 42 PSI front / 34 - 38 PSI rear (hot). Depending on the surface and so on, of course.
This produces fairly even temps across the tread, and so far wear is pretty even - a few percent more on the inside. I do like the tires - not the most economical choice, but a lot of fun.
I'm somewhat compulsive about tire pressure, these are my normal settings but I'll drop a couple of PSI if I'm planning some spirited driving on a warm day or will add some if I ever find an autocross on a day I have free.
I had the about same experience with the GY Supercars, and after some testing I ended up back at 30 PSI. I guess that it makes sense that they'd want less air, as the sidewalls alone are able to support the car.
Old Jul 22, 2010 | 08:00 AM
v8maro's Avatar
v8maro
Default TPS issue - reading abnormally high all the time.
meant to post a new thread
Old Jul 22, 2010 | 12:33 PM
GOLD72's Avatar
GOLD72
Originally Posted by corvette dave
I have 3 tire gauges at home that read the same. The tire pressure sensors in the wheels read 2 psi less than the gauges........
It has also been my experience that the TPMS sensors read 2 psi low (which of course is the safe approach to avoid under inflated tires). That experience is consistant across the two vettes and the one CTS I currently own.
Old Jul 22, 2010 | 12:46 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by GSIRM3
I continue to be amazed at the low pressures (30 psi cold) that Chevrolet recommends for the Corvette tires. Porsche recommends 39 psi in rear of my 911 for partial load and 44 for full load. Front is 33 for partial and 36 for full load. I have owned three previous e46 M3s, and the recommended pressures were 33 front and 38 rear for partial load, and 44 rear and 38 front for full load. The Corvette pressures are as low as I have ever seen for a performance car for street use.
I know you are going to say you will wear the tires out in the center with those pressures, but not so. My tires wear evenly across the tread with those pressures. In fact, too little air will cause ultra wide, low profile tires to wear in the middle because of the tire expanding out in the middle on acceleration. A tire with higher pressure will tend to maintain its shape better under acceleration and minimize that effect. Don't believe me? Check the tires on your cars. Most of you run 30 psi front and rear. I bet your rears tend to wear in the middle but not the fronts. Wonder why? It is because the rears tend to expand out in the middle under acceleration and the fronts of course do not. If it was not for that, don't you think your fronts would wear out in the middle also?
I think I disagree with part of this, but hopefully wolfie will post something.
