Rear end fluid
Old Aug 27, 2007 | 02:27 PM
Timothy Barth's Avatar
Timothy Barth
Default Rear end fluid
Looking through the owners manual I could find nothing about changing the rear end fluid only imformation about how to check the level.How often should this be done? Or is it a waste of money?
Old Aug 27, 2007 | 02:35 PM
C6~Missle's Avatar
C6~Missle
There is a drain and fill plug. It's an easy job with a pump for the new fluid. I change mine out at 15K miles and then at 45K.
It depends on how hard you use your car. It's good to change it out and go with a quality synth gear lube.
Old Aug 27, 2007 | 03:46 PM
Buffy's Avatar
Buffy
Although the manual doesn't call for replacing this stuff, I think its a good idea to do so. I did mine at first at around 3K miles and then went to an annual schedule. As C5~Missle said, use a good quality synthetic fluid. Most folks find they need at least one, sometimes two doses of the friction modifier, even with a synthetic gear oil to avoid the dreaded rear end chatter.
Its a little tricky getting the fill plug loose; make sure you can get that one free before you remove the drain plug! A short ball-end Allen socket is best for this, although a Bondhus - type ball-end L wrench will work.
A transfer pump works fine, but if your gear lube comes in the squeeze bottles you can also just use a foot or so of 1/4 inch tube on the bottles, then hold them up between the mufflers and squeeze. Let the mufflers cool first!
Old Aug 27, 2007 | 03:51 PM
Vet's Avatar
Vet
Here's a post from the forum FAQ... full instructions on HOW to change the differential fluid, plus other notes regarding the common "axle chatter" problem. Be sure to check the first 3 posts of this the thread:
http://forums.corvetteforum.com/show....php?t=1497063
Some feel it may be a good idea to change the differential fluid early to possibly reduce the chances of relatively early chatter. Others feel you may as well just wait until you start hearing chatter before changing... which may happen any time before 20k miles... (most commonly).
If you have nothing else to do and feel like tinkering, you can't really hurt anything by changing the diff fluid early... as long as you do it correctly and use the correct fluid and additive, correct amounts, etc. Most folks will probably tell you to just leave it alone though unless it's chattering.
Old Aug 27, 2007 | 03:56 PM
dchao's Avatar
dchao
Does the rear end chatter also occur on 2008 models?
Old Aug 27, 2007 | 06:24 PM
NORTY's Avatar
NORTY
Magnetic plugs available?
Old Aug 27, 2007 | 08:49 PM
Wayne88's Avatar
Wayne88
My 2006 chattered a little.
The dealer flushed and changed the fluid for free.
Old Aug 28, 2007 | 05:34 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I guess I'm still stuck in a time warp from the old days, but on new cars I always have the oil, transmission, and differential fluid changed around the first 1,000 miles just to flush out any remnants from break-in, machining, etc. After that, I go on the recommended schedule. I'm sure some may think its either not needed, a waste of money, or both. However, its my money and its worth it to me.
Old Aug 28, 2007 | 09:41 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
A C-5 magnetic plug is the same thread size.
Old Aug 28, 2007 | 11:05 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I've never had any problems with my transmission or differential but I recently changed my transmission fluid to Royal Purple. I was all set to change the differential fluid to Royal Purple but I decided to wait a while. With the 'rear end chatter' problems I read about so frequently, I figured if it isn't broke...don't fix it. I will, however, change it next month.
Do check the C6 FAQs page...it's a tremendous resource.
Old Aug 28, 2007 | 01:23 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
GM formerly recommended changes @ 100K.
I would think that 50k is just fine.
To Rear end fluid
