Cags Eiminator
Old Aug 29, 2007 | 04:28 PM
rrross's Avatar
rrross
Default Cags Eiminator
I puchased the skip shift eliminator from a forum vendor. I went to install it but it seems it was not that right one. I have a 2007 z51. One end of the eliminator had a blue cap over a white plug and the other end had a black connection which was covered. the instructions that came with it did not say you had to remove anything on the eliminator prior to installation. Any help would be appreciated.
thanks
Old Aug 29, 2007 | 04:56 PM
Modshack's Avatar
Modshack
Uhhhh....
Unplug from trans
Remove the blue cap,
Plug unit into harness
Put Cap on trans sender
Old Aug 29, 2007 | 05:13 PM
calemasters's Avatar
calemasters
Originally Posted by Modshack
Uhhhh....
Unplug from trans
That about covers it. Make sure you disconnect the CAGS connector and not the Reverse lock out solenoid.
Old Aug 29, 2007 | 05:25 PM
rrross's Avatar
rrross
Old Aug 29, 2007 | 06:34 PM
DRMN OF A VETTE's Avatar
DRMN OF A VETTE
Or buy the Predator Tuner. Tunes your car, even if stock and removes the CAGS. Whole process is about 2-3 minutes. You can go back to stock when you service your engine in less than 2 minutes so the dealer won't know that you have tuned your car. When you get home... 2-3 minutes later your tuned. The CAGS light does not appear any longer and your car will run like you kicked it in the a$$...Even if stock. Visit the scan and tune section under the forums.
Old Aug 29, 2007 | 07:29 PM
Wayne88's Avatar
Wayne88
Yup, there are 2 plugs down there.
Old Aug 29, 2007 | 07:42 PM
VET4LES's Avatar
VET4LES
Old Sep 2, 2007 | 01:02 PM
DigitalMan's Avatar
DigitalMan
Originally Posted by VET4LES
I have done this before but I just purchased a 2006 Vert and I cannot see this plug.
Where is the top part of the car in this picture?
Old Sep 2, 2007 | 01:15 PM
TR-6060's Avatar
TR-6060
This plug is high up on the driver's side of the transmission, in the middle part of the transmission lengthwise.
If you have a plug on the bottom driver's side of the transmission, it is the temperature sender (I believe Z51 only). Look for the CAGS plug above this.
Old Sep 3, 2007 | 10:30 AM
naschmitz's Avatar
naschmitz
On my 2006 the wire even has a factory label on it that said "Skip Shift" or something like that -- left no doubt I had the right wire and right solenoid.
To Cags Eiminator
