08 Rattle Problem
Old Sep 26, 2007 | 09:42 AM
z51vett's Avatar
z51vett
Default 08 Rattle Problem
A recent post about a rattle coming from pass side. I have this problem also, my wife says pushing on door panel stops it. Anyone else had this or know what the problem is.
Thanks in advance for your help.
z51vett
Old Sep 26, 2007 | 11:13 AM
MNVette's Avatar
MNVette
I've had a door rattle and a dash rattle - each time it was a panel clip that came loose and "banged" against it's metal connector on the dash. If you can push against it and make it stop, that means that the clip has come loose somewhere. Have the tech pull the panel off and reseat it on all the clips. That should solve it.
Old Sep 26, 2007 | 12:19 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Is it more of a rattle with a metallic sound or a squeak with the sound of something plastic that might be loose?
The reason I ask is that when I swapped out the door speakers on my 07, a few of the pins holding the door panel in place got considerably weakened. What happens now is that if I'm on the freeway I'll get an annoying little squeak that will go away if I push on the door panel.
Although it's doubtful that an 08 would have door pin problems it still might be a possibility.
Old Sep 26, 2007 | 07:04 PM
z51vett's Avatar
z51vett
z51vett
Thanks for the tips will look into door clips hope it that simple.
z51vett
Old Sep 27, 2007 | 11:54 AM
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
It seems like when I take my car in for this problem, the tech says he can't duplicate it. Very frustrating. I have a rattle from the vent area of the dash and a squeak from the driver's door.
Old Sep 27, 2007 | 12:08 PM
GAStateRep's Avatar
GAStateRep
I found that the parking brake button rattles from time to time. That may be the source of your problem.
To 08 Rattle Problem
