View Poll Results: When do you shift?
less than 1500 rpm
1
0.98%
~ 1500 rpm
4
3.92%
~ 2000 rpm
24
23.53%
~ 2500 rpm
28
27.45%
~ 3000 rpm
28
27.45%
greater than 3000 rpm
17
16.67%
Voters: 102. You may not vote on this poll
When do you shift??
Old Oct 8, 2007 | 12:03 PM
vette-oholic's Avatar
vette-oholic
Default When do you shift??
I've always used 3k rpm as the standard for upshifting during casual driving, so when I purchased my c6 - that's what i usually shifted at. well after 2 years of c6 driving i've just started shifitng at about 2k rpm and it seems like I get a more consistent smoother shift. Also, Im guessing my gas mileage should be a little better too.
what do you shift at when casually driving?
Old Oct 8, 2007 | 12:15 PM
su8pack1's Avatar
su8pack1
I shift by the sound and feel. I've never looked at the tac in 40 years of driving.
Old Oct 8, 2007 | 12:23 PM
SlowAzzVette's Avatar
SlowAzzVette
Not to sound rude but if you have to ask it means you are not used to an MN6 and need more training. you shift based on your driving, if youy drive aggressively, you shift at higher RPM's if you drive like an average driver, you want to keep the RPM's low but it is not always good for the engine. So in my regular driving i keep it at around 2k.
Old Oct 8, 2007 | 12:29 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Meee toooo.
Depends on the situation. I try to keep my cruise RPM above 1700.
Old Oct 8, 2007 | 12:34 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
1st and 2nd are usually between 3k-4-k (I love the sound of my Borlas). 3rd thru 6th depends on how I feel, but usually around 2.3k-3k.
Old Oct 8, 2007 | 12:36 PM
Buffy's Avatar
Buffy
Depends; but just puddling around town I'll shift at just over 2K (dropping to 1400) or skip a gear and shift one-three a little below 3K (again dropping to 1400). I base it more on where I'll end up than where I start out.
Old Oct 8, 2007 | 12:40 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
for the most part. Only time I use tac is when I'm doing some very close to redline driving. Other than that the engine will tell you when its time to shift.
Old Oct 8, 2007 | 01:15 PM
2bubbas's Avatar
2bubbas
It really depends-
Sometimes red line in 1st and 2nd if I want to get to the speed limit quickly or just for fun.
But mostly I shift between 2500 and 3000 rpm.
I do notice that the 2008 436 hp has cost me about 3 mpg over the 400 hp 2005. Same equipment- Z51- manual, etc.
Old Oct 8, 2007 | 01:49 PM
UTVOL06's Avatar
UTVOL06
I haven't owned a C6 mn6, but I do own a c6 z06. Not sure how much different shift rpms vary between the engines, but I doubt much since they both have fat torque curves.
During casual driving I shift around 2000rpms and stay in that particular gear until it drops to 1000rpms and then I downshift to get the rpms back up. So I basically try to keep my rpms around 1500 while putting around to conserve gas and engine wear.
I find myself in 5th gear a lot with the C6 Z06 ratio gears.
Old Oct 8, 2007 | 01:51 PM
H&J's Avatar
H&J
Just before my Iris is gonna separate from my Retina.
Old Oct 8, 2007 | 01:57 PM
0SicMSP - Daniel
Former Vendor
Old Oct 8, 2007 | 02:11 PM
User 020720's Avatar
User 020720
Normal driving: 3000rpm
Spirited driving (the kind that makes your a$$ pucker): 5500rpm
Wayne O's Avatar
Wayne O
CF Senior Member
I don't shift gears with any attempt to maximize gas mileage. I up-shift and down-shift depending upon the circumstances. I spent all day Friday and Saturday running on a road course constantly shifting close to red-line and running at very high RPMs. In daily in-town driving I shift much more 'conservatively' but I don't 'lug' around at extremely low RPMs. For me 5th and 6th gears are solely overdrive gears used for freeway or interstate driving.
I'm often surprised to read how diligent some Corvette owners are to shift at very low RPMs....some even coast to a stop in neutral without down-shifting at all which totally blows me away (and I feel is an unsafe practice).
Again, circumstances vary....I don't particularly look to up-shift or down-shift at any pre-set RPM.
Old Oct 8, 2007 | 02:24 PM
adias's Avatar
adias
Absolutely! Here we have an example of someone who drives a Vette as the car was designed to be driven. It is appalling either to read about burnouts/drag strip boy-racer meaningless exercises, or 1200RPM cruising. This car was designed to be exercised on a road course using its full RPM range.
Old Oct 8, 2007 | 03:00 PM
rsmithuf's Avatar
rsmithuf
Im curious to why you think coasting in neutral to a stop (with brakes also being applied) is a "unsafe practice." The only thing I can think of why this would be unsafe is if you didn't use the brakes as well to warn drivers behind you that you are slowing down.
Old Oct 8, 2007 | 03:09 PM
StanNH's Avatar
StanNH
Originally Posted by JFTaylor
Meee toooo.
You shift by sound? You're so hard of hearing I'm amazed you haven't blown the engine yet.
Old Oct 8, 2007 | 04:43 PM
johnnyhulk's Avatar
johnnyhulk
To When do you shift??
Old Oct 8, 2007 | 04:46 PM
johnnyhulk's Avatar
johnnyhulk
the reason that`s is unsafe is that you don`t have total control of the car when it`s in neutral. what happens if you need to maneuver???????
Old Oct 8, 2007 | 04:50 PM
vette-oholic
you missed the point.. i never said i looked at the tac..
But that's the only easy way to communicate to people on here when you shift.
of course, this assumes non-spirited driving... flat roads, etc
Old Oct 8, 2007 | 04:58 PM
johnodrake's Avatar
johnodrake
Moderator
In the lower gears - out of traffic - I normally am at about 3K - 4K. But then I have 4.10 gears......
