broken rear leaf spring
Old Oct 12, 2007 | 11:09 AM
Sinister Evil's Avatar
Sinister Evil
Default broken rear leaf spring
I think I cracked the rear leaf spring again because I heara creaking noise in the rear that sounds like the last time I broke it along with the WCC lowering bolts. Is my car too low?
Does anyone know a good place to get a good deal on a new leaf spring? Cost?
'06 C6 lowered to the max WCC bolts will allow on front and rear.
Old Oct 12, 2007 | 11:22 AM
Wayne O's Avatar
Wayne O
CF Senior Member
If, in fact, you did break your transverse leaf spring for a second time I don't think you need to ask if your car is too low.
I'd check with Gene at gmpartshouse.com for a replacement. Good luck.
Old Oct 12, 2007 | 01:16 PM
Sinister Evil
thanx. Got a grt deal on it for about $150.00 less than dealer was asking.
Old Oct 12, 2007 | 01:18 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
How is your spring breaking?
Old Oct 12, 2007 | 01:43 PM
Fast stuff's Avatar
Fast stuff
Default dejavu
I broke one on a 94 coupe and it was because I used to clean the undercarrage aluminim with an acid aluminum wheel cleaner by Eagle 1. We did not know it then but now we know it erodes the epoxy in the fiberglass spring. Now in the owners manuals it states not to use the stuff - have you been using it??
Old Oct 12, 2007 | 02:50 PM
cadguymark's Avatar
cadguymark
no way dude, lowered is sic, totally worth it, I say lower it more
the Vette is all about image and style, you posers driving 'em because they are fast are just fowling up mother earth with hydrocarbons and ya'all probably live in a trailer park and get your TV reception thru busted rabbit ears.
Old Oct 12, 2007 | 02:54 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Maybe, but I bet they can construct a sentence. Those who live in glass houses.......
Old Oct 12, 2007 | 02:56 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
Who teach-ed you how to spoke?
Old Oct 12, 2007 | 03:02 PM
Maui's Avatar
Maui
St. Jude Donor '08
That's not nice.
Old Oct 12, 2007 | 03:08 PM
djfullshred's Avatar
djfullshred
So having the car just for looks is not being a poser, but driving it is?
haha, put the crack pipe down.
Old Oct 12, 2007 | 03:12 PM
71stang99's Avatar
71stang99
You are a fool; I don’t appreciate being lumped into a "poser" because my car is not lowered. You just really showed how intelligent you are and your ignorant stereotype about living conditions which probably reflects where you grew up and how much you hated it.
Old Oct 12, 2007 | 03:22 PM
User 020720's Avatar
User 020720
Old Oct 12, 2007 | 05:31 PM
cadguymark's Avatar
cadguymark
now that is a man with style
Old Oct 12, 2007 | 07:38 PM
Brabus2's Avatar
Brabus2
I've got both front and rear leaf springs sitting in the garage with approx. 5K miles on them....will sell cheap, let me know if your interested.
Old Nov 5, 2007 | 03:39 PM
Sinister Evil
Thanks for all the replies. i haven't had time to even investigate my rear end. I haven't driven my car in about 3 wks. I'm going under her today to check everything out. I did a visual a week ago without jacking the car up and couldn't see any breaks on the rear leaf spring or the lowering bolts which apparently failed the last time I busted the spring (k).
QUESTION:
Would the rear composite leaf spring show cracks or has it just lost its ability to "spring".
I will check tonight now that I have time.......I didn't touch the car due to my State of CA Professional Engineer licensing Examination....now it's time to find the problem and play!!!!!!
Old Nov 5, 2007 | 05:52 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
A newbie engineer. That explains a lot!
Tom
Old Nov 5, 2007 | 06:05 PM
mlongo99's Avatar
mlongo99
I cannot believe you just asked this question right before stating that you were taking the PE exam.
The spring breaks via delamination. The damage should be pretty obvious.
To broken rear leaf spring
Old Nov 6, 2007 | 09:42 AM
Sportsdude's Avatar
Sportsdude
Have you thought of going with coil-overs instead? It's more expensive though.
Old Nov 6, 2007 | 06:51 PM
Cjunkie's Avatar
Cjunkie
Originally Posted by sabooher
as many people as he crashed, he deserved to be put into the wall.
Old Nov 6, 2007 | 06:57 PM
Ozone's Avatar
Ozone
I use the Dupont wheel cleaner with teflon on the wheels only. Is this something I need to be worried about?
