shifting issues
Old Nov 20, 2007 | 03:24 PM
octane_n_veins's Avatar
octane_n_veins
Default Could be....
Could be the skip shift. On all manuals, the transmission will make you shift from 1st-4th when driving in traffic or light to light. But if you giving it a lot of gas, aka high RPM’s, you shouldn’t get the 1st to 4th shift at all. The transmission is made like that to help optimize on fuel economy. If it becomes annoying then buy a skip shift eliminator. You pick one of those up for about $25 at just about any where.
Old Nov 20, 2007 | 03:36 PM
johnodrake's Avatar
johnodrake
Moderator
I have driven several different T-56s and one T-6060 and never experienced that issue. The T-6060 syncros are improved and the gears are cut differently so that shifting should be effortless - The T-6060 that I drove on the track was very smooth indeed.
Old Nov 20, 2007 | 06:14 PM
User 020720's Avatar
User 020720
I've had my 07 almost a year now and not once have experienced anything like you've described.
It's a little more difficult to shift when the engine is cold and hasn't warmed up yet but that is normal.
Old Nov 20, 2007 | 06:25 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
The low engagement point is a strong clue -- it sounds like the clutch is not fully disengaging, which would result in exactly the shifting problems you describe. Definitely a trip-to-the-dealer issue, sorry!
Old Nov 20, 2007 | 06:48 PM
Futile's Avatar
Futile
Originally Posted by elofdahl
That is not normal! Get it to dealer before more damage is done.
Get it to Dealer!
Never had shift probs since day ONE.
'08 - MN6, Z51
967 miles now (delivery 10-10-07)
Hard accel - Unless you are blowing the shift on hard accel, Pull & push. (Slips right in & out)
Light accel - (maybe your trying to overcome CAGS) Don't, just accel through 'til light goes out.
Old Nov 20, 2007 | 06:55 PM
titanit's Avatar
titanit
Default Shifting
My 07 was hard to shift at first but as the miles pile on (1157) it is getting easier every day. The thing that bothers me the most is the 1st to 2nd lock out (1-4) what a pain.
Old Nov 20, 2007 | 06:56 PM
JJC5's Avatar
JJC5
Someone mentiond skip shift..that's possible. I have an '07 and when it's cold, double clutching helps. Another way is when you shift, pause briefly at the syncro to let it catch up then finish the shift. When the trans fluid is cold, the syncros don't spin up as fast and therefore need a little time to catch up.
Old Nov 20, 2007 | 06:58 PM
JJC5's Avatar
JJC5
Get the skip shift eliminator. Piece of cake to install too.
Old Nov 20, 2007 | 07:01 PM
FLHXI06's Avatar
FLHXI06
Originally Posted by garye
For a $50,000 car I can't believe it shifts the way it does. An 08 MN6 and going from 1st to 2nd and 2nd to 3rd it is hard as hell to shift. After about 1/2 hour it seems to shift better but it's still not great. I'm 6'4" so it's not about being able to put the clutch to the floor, as a matter of fact the clutch doesn't engage until about the last 2 inches. Is this normal. I can't stand the grinding.. I called the dealership and they said to put a few more miles on it before coming in, I have 580 on it now. You can actually feel it finding it's way into gear one notch at a time, and sometimes actually grinding the gears. $50, grand for that???? My 66 GTO was better.
You think thats bad drive the 08 A6. Piece of CR$P
Old Nov 20, 2007 | 10:02 PM
Sayfoo's Avatar
Sayfoo
This IS a problem with the 08's. Look at the other postings on the forum. It is not skip shift related. It is not driver error. It is not clutch related. Per my e-mail reply from the factory.
Old Nov 21, 2007 | 10:49 AM
titanit's Avatar
titanit
Default Shift problems
JJC5 - Any idea where I go for one? Thanks, Titanit - Camarillo
