shifting issues
Old Oct 15, 2007 | 11:51 PM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
Default shifting issues
For a $50,000 car I can't believe it shifts the way it does. An 08 MN6 and going from 1st to 2nd and 2nd to 3rd it is hard as hell to shift. After about 1/2 hour it seems to shift better but it's still not great. I'm 6'4" so it's not about being able to put the clutch to the floor, as a matter of fact the clutch doesn't engage until about the last 2 inches. Is this normal. I can't stand the grinding.. I called the dealership and they said to put a few more miles on it before coming in, I have 580 on it now. You can actually feel it finding it's way into gear one notch at a time, and sometimes actually grinding the gears. $50, grand for that???? My 66 GTO was better.
Old Oct 16, 2007 | 12:15 AM
B-Myster's Avatar
B-Myster
You definitely have something wrong. I've driven mine with just about 500 miles on it fairly aggressive (11 mpg last tank ) and it shifts very smoothly (no grinding) from gate to gate without the friction that you are describing with yours. My clutch also seems to engage more towards the top as well.
Old Oct 16, 2007 | 12:40 AM
tmak26b's Avatar
tmak26b
I have trouble getting into gear myself, the gearbox on this car isnt exactly the best unit
Old Oct 16, 2007 | 12:42 AM
WMark's Avatar
WMark
St. Jude Donor '11
You have a problem (not you, your car!). My C6 M6 shifts better than my C5, which is a welcome improvement. I've had to get used to the C6 vs the C5 when it comes to the clutch. My car (nor my old C5) doesn't operate anywhere near what you are describing. For the performance/$$ I'm very satisfied with my M6.
If your dealer can't fix it, find a new mechanic!
Good luck!
Old Oct 16, 2007 | 12:48 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Not normal !Mine has loosened from 500 miles but was always light now at 4500
my 08 is sweet as sin! But my 02 Z was horrible till I changed the fluid U need to at least change the fluid with red line or royal purple. !
That will help
Old Oct 16, 2007 | 01:07 AM
elofdahl's Avatar
elofdahl
That is not normal! Get it to dealer before more damage is done.
Old Oct 16, 2007 | 01:26 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I don't have the new 'improved' 2008 gearbox but my 2005 MN6 shifts great...no problems at all. If you're experiencing any grinding I'd get the car to the dealership ASAP....that ain't right.
Old Oct 16, 2007 | 01:45 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Definitely not normal for an '08. They are said to shift better than prior models and the pre '08s did not shift bad.
Old Oct 16, 2007 | 01:55 AM
FLY US's Avatar
FLY US
Gary, how many miles were on the car when you took delivery,
we've heard some stories about 08 test drives.
My 08 shifts perfect
Old Oct 16, 2007 | 06:05 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Old Oct 16, 2007 | 07:17 AM
robl45's Avatar
robl45
It all depends on peoples definitions of what is normal.
My c5 shifted like crap and my new 08 shifts better but is still not super. You have to guide the gears pretty carefully. I had previous cars where you could really shift.
Try shifting slower and see if that solves the problem. If not, you really need to see the dealer.
Old Oct 16, 2007 | 08:36 AM
C6~Missle's Avatar
C6~Missle
I'm used to vette manuals and the 08 is the smoothest to operate by a wide margin. It does get even smoother after warm up. Sounds like you may have a problem.
These are very stout trannys.. It will take some effort to move the internals as they are beefy. It's not a Honda civic with a tranny the size of a 5 pound bag of sugar..
Old Nov 20, 2007 | 02:39 PM
SnowyATX's Avatar
SnowyATX
My ~1K miles '08 shifts kinda crappy for the first 5-10mins when shifting from 1st to 2nd. My assumption is that once its slightly warmed up the problem goes away.
Old Nov 20, 2007 | 02:56 PM
Modshack's Avatar
Modshack
At 7K miles my '08 is perfect. A little stiff when cold, but Never experienced the issues you describe..
Old Nov 20, 2007 | 02:59 PM
StanNH's Avatar
StanNH
The 2008 gearbox is supposed to be even smoother shifting than the previous ones, and my 2005 MN6 shifts easily into all gears. I'll join the chorus in saying this looks like a service issue.
Old Nov 20, 2007 | 03:01 PM
VET4LES's Avatar
VET4LES
Old Nov 20, 2007 | 03:04 PM
BonB's Avatar
BonB
6th Gear
How many miles do you have so far? I have about 350 on a 08 coupe Z51 manual. I find shifting to be pretty notchy compared to other manuals I have driven (feels like I hit a couple of kinks with each throw, but no grinding). I assumed this would loosen up over time.
To shifting issues
Old Nov 20, 2007 | 03:08 PM
SvetteC6's Avatar
SvetteC6
My 05 isn't consistent. It's hard to find the gear and once you hesitate and leave it in nuetral it's really hard to get in. After a half hour ride this weekend I filled it up with gas and I could not get it into 1st without grinding, alittle. Other times it's great???
Old Nov 20, 2007 | 03:16 PM
HAIL THI$'s Avatar
HAIL THI$
Normal driving on my 06 is fine. But some times when I'm out have fun and I need to get from 1st to 2nd at track like speeds it has done the whole grinding thing. Its almost like it trying to activate the skip shift. This has happened maybe 3 times in the year + I've had the car. Being me I just thought it was me missing a gear, but after reading here I'm not sure now.
Old Nov 20, 2007 | 03:22 PM
Walt White Coupe's Avatar
Walt White Coupe
Your transmission/clutch has a problem. Engagement should be around mid-pedal travel and it should never grind. These kind of problems rarely cure themselves.
