Alignment Question
Old Oct 18, 2007 | 09:23 AM
Blue2015's Avatar
Blue2015
Default Alignment Question
I have 22,700 miles on my '05 Z51, original rubber still on the car.
I don't baby the car. I've taken it to an Autocross once. I do suspect that the reason they lasted as long as they did is that I had the car aligned within a couple weeks after taking delivery and one more time after that. I asked for the before & after printouts and the 'before' settings were off both times.
In any case, I noticed some odd chunking on the left rear tire.
I suspect that this is an indication that the alignment is off again. Can anyone confirm?
Old Oct 18, 2007 | 09:27 AM
07MontRedcp's Avatar
07MontRedcp
Never seen anything like that before, but then I'm not a racer.
BJK
Old Oct 18, 2007 | 09:37 AM
Modshack's Avatar
Modshack
Seen this here before...Always on cars that had track time...I suspect your alignment is fine if you've managed to milk that many miles out of them. Old tiresand high heat cycles from your driving style probably contributed more...
BTW,Those tires don't owe you a thing!
Old Oct 18, 2007 | 09:49 AM
Blue2015's Avatar
Blue2015
Don't get me wrong, I'm not complaining about the mileage I've gotten from these tires.
Also, the few AutoX runs that I had done were in 2005, a few months after getting the car.
Old Oct 18, 2007 | 09:55 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Even with the one autocross and somewhat hard driving you're getting (or got) modestly decent mileage out of those tires. If there aren't other signs of unbalanced tire wear, I would not suspect alignment. IMO an autocross can be a violent event for your tires. Did you notice this immediately after your autocross event? I'd keep an eye on the tire until you replace it but wouldn't worry about alignment.
Old Oct 18, 2007 | 10:00 AM
Blue2015's Avatar
Blue2015
I noticed this odd wear this past weekend.
I often pull the wheels off to clean the insides of the rims. This was the first time I noticed this.
Old Oct 18, 2007 | 10:06 AM
gimme5's Avatar
gimme5
If under-pressured that could happen. I run at 35 psi all the way around. Don't know if that's the norm; I just do.
Would be glad to hear what others run.
Not a track-person either; but, have had my spirited moments on the street.
Old Oct 18, 2007 | 10:12 AM
07MontRedcp
That's what I was thinking. Side wall flexing due to low a tire pressure
causing an abnormal flex wrinkle were the tread and side wall meet. Just a guess.
Also, I agree that the alignment is fine. No evidence that camber or toe in/out are off.
BJK
Old Oct 18, 2007 | 10:13 AM
z06Bigbird's Avatar
z06Bigbird
Your post reminds me of my 76 Toronado. When alignment shop told me I did not need an alignment, I told them that I had not aligned it in 10 years. They said that was because it was a 'real' car--almost 5000 lbs. Looked underneath it, and front end parts looked like they were made for a bulldozer. Those were the good old days.
Old Oct 18, 2007 | 03:06 PM
heisnuts's Avatar
heisnuts
My original Goodyear GS-2's (the non Z-51 tire) did the exact same thing about half way through their life. Never really had any problems with them and they wore right through the chipping over time. I always run 30lbs cold but do drive in a lot of mountain pass type roads with sharp turns with a 55 mph speed limit. I suspect that had a lot to do with the wear
Old Oct 18, 2007 | 03:25 PM
AutoCutter's Avatar
AutoCutter
The tire was run hard before getting the tires up to temperature. You see this type of chucking on F1 cars when not allowed to come up to temp.
By the way, alignment spec's last until you drive the car on the road then they are no better then the last bump you hit!
Old Oct 18, 2007 | 03:52 PM
Blue2015's Avatar
Blue2015
I suppose that's possible. How long does it typically take for these tires to warm up? (in Florida.) In other words, how does one know if the tires are warmed up?
Old Oct 18, 2007 | 04:10 PM
EvilBoffin's Avatar
EvilBoffin
St. Jude Donor '09
The tread appears to be very close to being worn to the level of the wear indicators along the centerline of the tire.
I think these new 'half moon' shaped chunks are nothing more then a function of wear down to this point. They are only showing up now because you have worn the tread down to the 'magic' point where these extra sipes wear through the tread block surface and become exposed. Maybe it's sign from Goodyear that it's time to buy tires?
It's also possible that excessive temps when the tread was thick could cause them to pop up prematurely.
I doubt it's anything to panic about, but just be aware that these tires could now be VERY treacherous in the rain. Even really good wet performance tires (Michelin Pilots, Goodyear F1 GS-D3's, etc.) can make for a sudden white knuckle ride when they wear to this point.
So take it REALLY easy in the rain til you get some new shoes...
Old Oct 18, 2007 | 04:14 PM
07MontRedcp
BJK
Old Oct 18, 2007 | 04:21 PM
Modshack's Avatar
Modshack
Monitor the pressures on the DIC. When the indicated pressures increase roughly 2 psi over the cold pressures, they are probably warm...
Old Oct 18, 2007 | 05:17 PM
orca1946's Avatar
orca1946
Will you get the same tires or try some other brand?
Old Oct 18, 2007 | 08:02 PM
Blue2015's Avatar
Blue2015
When I saw how they far down they were worn this weekend, I made up my mind to get new tires soon. I had the Firestone WideOvals put on this afternoon. We'll see how they do.
Added bonus- the manager at the Firestone said that if I don't like them I can bring them back and have the F1 Supercar tires put on. Not planning on doing that, but it's nice to know that I could if I determine that these tires won't do it for me.
To Alignment Question
