"Performance" street alignment specs?
Thanks!
http://forums.corvetteforum.com/show....php?t=1795091
BJK
FRONT:
-1 DEGREE NEGATIVE CAMBER
6 DEGREE CASTER
0 TO 1/8 TOE-IN
REAR:
-3/4 DEGREE NEGATIVE CAMBER
1/8 TOE-IN
This seems to work fine on the street as well.
FRONT:
6 DEGREE CASTER
0 TO 1/8 TOE-IN
REAR:
1/8 TOE-IN
These are for the coupe and the convertible
http://forums.corvetteforum.com/show...87&postcount=8
The Z06 goes to a -1.0 on the front camber
Elmer
I'm running a Z51 with Z06 rear bar and PS2s, stock shocks (for now).
I find that the PS2s like a bit more pressure than the GYs, I run about 36 front / 33 rear (cold).
I increased the camber on the stock tires a couple of times, ended up running -1.3 front / -0.9 rear and still had more wear on the outside than the inside. I've backed off a bit to about -1.0 front / -0.75 rear on the PS2s, which seem to do a better job of keeping a flat footprint.
Reducing caster some from the rather high factory value helps steering sensitivity quite a bit. You may need to reduce it a bit anyway to get enough negative camber. I'm at about 6.5 but likely to drop it another 0.5 or so soon.
There seem to be many different opinions on toe, but you don't want much. A little bit goes a long way with these cars. A bit of toe out front may give a little faster turn-in, but a bit in may be more comfortable to drive. I think the combination of front toe-in and reducing caster gives me the best combination.
In any case, about 1/2 as much toe in the opposite direction on the rear seems to work well for me. I'm running about 0.1 degree in front / 0.5 degree out rear (per side).
Tread wear on the PS2s with these settings is quite even, and temps are fairly even, with the insides just a little warmer than the outside after a "spirited" run down a favourite road
