Delevery Prpblems
Old Nov 15, 2007 | 12:49 PM
bgautodeal's Avatar
bgautodeal
Default Delevery Prpblems
Ordered a new Z06 through my local dealer and when the car arrived the car would not start, all the lights would come on so there was power. The dealer told me that there is a security fuse installed at the factory that prevents the car from running. The fuse must be replaced by the dealer. Well it's been 7 days since my car arrived and I am yet to take delivery. Now the dealer called and said the car is ready. Thinking about telling them to keep the car and get me another Z06. What do you think?????????
Old Nov 15, 2007 | 12:53 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Your car arrived and it wouldn't start. It now will start and you want to send it back. I think you are nuts. Don't read so much in to things. Go pick up the car, drive it and enjoy it. It really isn't that big of a deal.
Should have mentioned that I've never heard of this "security fuse" I suspect the battery was dead (low enough not to start the car, just enough to light the lights.)
rws.1's Avatar
rws.1
smells fishy.....
Old Nov 15, 2007 | 12:59 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
"security fuse"? My dad delivered cars for years for Leaseway and I know he didn't push the vettes on and off the trailer. Of course this was 10 years ago so things might have changed. I would at least go drive it around and check it out before taking title.
Old Nov 15, 2007 | 01:00 PM
DaveC6's Avatar
DaveC6
First off, I'd go get the car, probably no big deal. But how do they get them all off the truck if there is a security fuse and none of them start? I'd call then I'd ask them to tell me what was really wrong with it first.
Old Nov 15, 2007 | 01:06 PM
routesixtysix's Avatar
routesixtysix
I would go to the owner feedback section on http://bowlinggreenassemblyplant.com/ and ask about it. I've asked questions there and gotten a response within 24 hours. You will need a VIN to use it however.
Last edited by routesixtysix; Nov 15, 2007 at 01:07 PM. Reason: update information
Old Nov 15, 2007 | 01:09 PM
mpuzach's Avatar
mpuzach
Excellent idea.
Old Nov 15, 2007 | 01:46 PM
markcz's Avatar
markcz
The "security fuse" is BS. Make sure the dealer knows that you know that
Tell them you want a printout of the cars service history BEFORE you agree to take delivery. Whatever they did should be on it, I'm guessing it was just an almost dead battery. Also, make them hook the car up to a scanner and print out all of the trouble codes, and then clear them all out. Then the car will be good as new.
Old Nov 15, 2007 | 01:55 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree, pure BS from the dealer. Probably they had no clue so they came up with a reason to make you think it was normal.
Old Nov 15, 2007 | 02:27 PM
mowdoc's Avatar
mowdoc
It does not take 7 days to change a fuse or charge a battery - even if they had to order the parts!!
I suspect they spent 7 days trying to figure out how to fix what what was broken. (poor techs)
Then they handed you a load of BS. (untruthful dealer)
Odds are - the Vette is fine now. BUT you have just been given some valuable insight on how this dealer operates.
The ball is now in YOUR court - - whatcha gonna do???
mowdoc
Old Nov 15, 2007 | 02:49 PM
VetteManRay's Avatar
VetteManRay
From: Forest Hill, (Out in the country), north of Baltimore. Maryland. Land of "Pleasant Living" with my Corvette, steamed crabs & crab cakes.
Default Smells
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
of the fourth degree. A bad battery or a clutch safety switch.
Get a printout as others have said.
**CHECK the MILAGE***, see if they were doing a little demo driving with YOUR car.
Old Nov 15, 2007 | 03:08 PM
SimonStern's Avatar
SimonStern
Delevery Prpblems
YOU expect perfection?
Old Nov 15, 2007 | 03:21 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
You've got a dealer with a proven track record of dishonesty and incompetence. Unfortunately, that isn't unusual. If it were I'd walk but since the odds are good the next dealer you encounter wouldn't be much better...
Get the printed record from GM of what they did. If it was just a dead battery or bad FOB, take the car and figure out where you are going to go for service. If it was a real problem that could actually take 7 days to fix you might have a case for refusing that car and getting a good one. For example, if they replaced an engine that they blew up driving it off the truck...
Fcal's Avatar
Fcal
Was it a salesman that told you this, or the service mgr.? Most salesmen don't know Jack **** about the cars they sell. Excluding the dealers on this forum who seem to know their cars.
When I was looking at verts locally, not one of the salesmen knew how to manually open the tonneau cover.
Get the printout for peace of mind, then go out and drive the hell out of that car.
Old Nov 15, 2007 | 05:23 PM
SteveTurner's Avatar
SteveTurner
Old Nov 15, 2007 | 05:24 PM
VettinFan's Avatar
VettinFan
I'm sure the car is fine now, but my biggest concern would be..why did it take them 7 days to get the car started? Just what did they do, and or replace before they released the car.
Make sure you have all this documented.
~AL~
To Delevery Prpblems
Old Nov 15, 2007 | 05:30 PM
WFO's Avatar
WFO
As long as you haven't driven the car off the lot, it's your call. It's not been plated. It has been Titled though. I think it's still your call. I wouldn't over think this. Crap happens.
Why it took 7 days, hmmm...I'd have been the squeaky wheel long before that.
After 2 days and no dilivery, speaking with the Service manager and the Sales manager would be main objective.
You became customer service priority when that car rolled off the transfer truck. If it was a part they were waiting for, then you would known it, because you would have asked.
Be happy, go hug your Z06. I'm jealous.
Old Nov 15, 2007 | 05:31 PM
C6NRED's Avatar
C6NRED
SECURITY FUSE????????
That's almost as funny as if they told you it was the muffler bearings.
Some good advice above....a lot better than the dealer gave you when the car would not start. The best idea above is to get the service printout on the car and have them clear the codes.
Don't make any decision on the car until you REALLY know what was wrong. These care are immensly complicated and complex machines. Something as simple as a dead battery or clutch switch should not prevent you from taking delivery and enjoying the heck out of a ZO6......I'm jealous.......
Old Nov 15, 2007 | 06:43 PM
14 Red Z51 Vette's Avatar
14 Red Z51 Vette
This story reminds me of a time when my wife bought a brand new 95 Camaro. The car was 2 days old with 160 miles and she was on the interstate coming home and it died. By the way, she was 6 months pregnant. Fortunately, her step Dad saw the car and knew it was her somehow and came to the rescue. The car went to the selling dealer on a roll back where it stayed for 4 days trying to figure it out the problem. It was a bad crank sensor. We tried to get them to take the car back with all the smudge on the black fenders and all, but they refused. Within 3 months I was trading it in on a Toyota Camry which really was tight financially with a new baby.
