which digital camera?????
When you downrez (decimation), you need to sharpen a bit afterwards. Uprezzing (interpolation), a bit of smoothing is called for. These options are available as Bicubic Sharper and Bicubic Smoother in the Image Size panel.
You certainly seem to have a handle on Photoshop and Photography
You're right about the process 1-5 over, and over, and over
I've only been shooting 5 years and mostly my, kids sports, soccer, baseball. A little nature, macros, and family events indoor with slaved bounce flash and onboard fill flash. I've been using a Cannon 20D for the last 3 years, and it's my first SLR and only second digital. I'm having lots of fun and think I'm learning, thank goodness it's digital. Yeah, I'm a cheapskate
I have thumbed a few books at the library, and learned tons at dpreview for 3 years.So my question to you is, the bicubic smoother for up sizing ? I've never heard of it for this, mostly have heard to add more sharpening. Part of me sees how the smmother makes sense, can you explain more or give me some links to further my knowledge please.
A few days ago I uploaded a file for a poster 18x24 and upsized it 10% twice. So about 20%, I also doubled my normal amount of sharpening. I hope I didn't to too bad with this process, what do you think ?
This link is to pictures I was shooting and printing, comments are welcomed
even bad ones
http://forums.corvetteforum.com/show....php?t=1854244
Thanks, Greg
I think the correct order is: Be sure you crop before resize.
1) crop
2) resize say 800x600, @ 72 or 96 dpi
4) sharpen a bit, and view at 100% to see true results
3) save as, or for web, jpg quality about 80 percent
Depending on the complexity of the image, the above processes should give you a file size between 80k - 120k. If your sizes are much smaller do less JPG compression and check your dpi or ppi.
If you keep making changes to the same photo, and save as with JPG compression, the image will degrade each time. Do all your processing with that photo and save first, before resizing smaller, with the highest quality jpg for making a print later. Then you can open that one and resize once and sharpen a bit for the web.
If you need to make editing changes later, start from the origional. Or if you know you will make changes later, save as PSD for Photoshop to keep layers open, or if not using layers save as Tiff. not JPG.
I use Photoshop for the inital editing and croping and save as highest quality jpeg. Later I'll batch resize for the web using "irafanview" a free program. It is a really slick program for many things, I use it to make slide shows with music too. I just started using photobucket also, really easy to embed images for the web.
Good luck, hope this helps
GregYes, I already do all those things (except the web programs). I'm using MGI Photosuite.
Thanks!
Here is a scary photo:
Time Elapse fun... bonus points if you know where this was taken:
QUOTE]
Don't know where you shot this...I'm still trying to figure out how you have time lapse with the back-up lights
So, I tried saving it as a .bmp file and they dark blotches did not look nearly that bad - almost not noticable. Unfortunately, the Corvette forum file manager won't let me upload a .bmp file. I'm stumped.
<<EDIT>> Thanks to ya'lls advice, I found some settings I was not aware of - picture turned out MUCH better.
What you need to look for is:
1. Resolution in mega-pixels. Get nothing less than 3 mg. Best range is 5-8mg. Any more than that in overkill.
2. Optical zoom. Digital zoom does nothing. 6-12x is top of the line.
3. Lens size. Most digitals have small lens openings and high zoom capabilities to compensate. F2-3 is the norm. You will not get the f1.2 range unless you buy one of the $1000 boys. The smaller the “f” the lager the lens opening. Large is good cuz it lets in more light.
4. LED screen. 2” is the norm. Some have pop out & swivel capabilities. The LED negates the need to put the camera up to your eye. The swivel feature is great for setting the camera low to the ground or holding the camera over your head and using it sort like a periscope. To me that’s a super capability that I would always want to have.
I have a Cannon S3-IS. 6 mg-pix; 12x optical zoom; f2.1; swivel LED for less than $300. I think Cannon recently introduced a S5-IS with 8mg pix and most of the same features. The IS stands for "Image Stabilization".
Go to CNET.com. They explain functions & capabilities well with short videos on different models.
Looking at this iamge, I say it was shot at 300mm or very, very close to it...
From what I can see, your program which I have no experence with, is applying too much jpg. compression. Is it adjustable ? Those size images should be at least 60K, you got 25 - 30K there, too much lost information. Since your hosting images from your own website, you don't have size limitations. Try for minimum compression and they maybe 150-200K and you will see vast improvement.
I noticed on your website, which is very nice
If you want to send me a full size image, I can show you what high compression levels can do to hurt an image.
Greg
Leica markets the same camera... (and it costs $600+ more...) My pics are junk but I'm no photographer and I don't electronically molest pics either.
Here's one~
See, I told you they're junk!
GregI'll check the settings on my other program as well. I really appreciate all who are making suggestions! I'm picky as hell about pics, but I just haven't taken the time to figure it out!!!
I think it's not time lapse but rather dragging the shutter while backing up that made this shot....
Look under syncing of the flash curtain.
BTW, there's some pretty serious blur on the nose...
