Brake Noise
Old Nov 30, 2007 | 07:33 PM
gphair's Avatar
gphair
Cruising
Default Brake Noise
I have an 06 Vert (15K miles) with brake squeal. Anyone else had this problem and if so, what's the fix? Local dealer is clueless.
Old Nov 30, 2007 | 07:35 PM
not08crmanymore's Avatar
not08crmanymore
The quick fix you can do is get the car up to 40ish and hit the brakes firm and hard.Do this 5 or 6 times.Should eliminate the squeal forever.It did on my 05 z51.Next to that,it's HAWK PADS or something.
Old Dec 1, 2007 | 08:50 PM
jpgolf14's Avatar
jpgolf14
There has been lots of discussion on this subject. First try bedding the brakes. If that does not work, and you don't track your car, try ceramic pads. I got mine from Gene Culley.
Old Dec 1, 2007 | 09:11 PM
siffert's Avatar
siffert
The correct way is to go to 60, hard on the brakes (just to the point of lock-up) back to 10, then back to 60 and do this about 8 times and then drive for about 5 minutes without stopping to cool them off. Then they are properly bedded in and you can then vomit!
Old Dec 1, 2007 | 11:24 PM
not08crmanymore
I know,but 40 is safer when writing in a thread!
Old Dec 1, 2007 | 11:26 PM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Z51?
Old Dec 2, 2007 | 12:09 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I agree...try bedding the brakes. Start a little bit more gradual to bring the brakes up to temperature first...here is a decent article on the subject:
http://www.zeckhausen.com/bedding_in_brakes.htm
I'm always surprised how common this complaint is. I've hardly had any brake squeal and never a problem with brake dust (even when I used stock brake pads).
Old Dec 2, 2007 | 02:56 AM
geoffliz's Avatar
geoffliz
My Hawk HPS's groan/grunt at the final point of stopping and first point of rolling off. I made this point in a thread of my own, recently, and got no responses from other Hawk users
Old Dec 3, 2007 | 02:05 PM
gphair's Avatar
gphair
Cruising
Thanks, guys. Very helpful suggestions.
To Brake Noise
