Remove Oil Plug Without Using a Jack!
Old Dec 9, 2007 | 12:38 PM
hulksdaddy's Avatar
hulksdaddy
Originally Posted by ProfMoriarty
Call me Clyde and toss me a banana!
I have 36" sleeves, leave the wheels straight, and just lie on my back and reach under to flip the lever on the Fumoto valve I have installed.
How long have you had it, and do you have any pics of it? Any chance you can see of the lever being flipped accidentally by road debris or the like?
Old Dec 9, 2007 | 12:44 PM
carpe dm's Avatar
carpe dm
Originally Posted by burtonbl103
I prefer jacking up and double checking everything myself
Put it on jack stands and take the time to check everything under there. Good therapy and exercise.
Old Dec 9, 2007 | 12:46 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Thats what i tell my wife
My vette is "therapy"
Old Dec 9, 2007 | 12:48 PM
ProfMoriarty's Avatar
ProfMoriarty
I installed it after the first oil change I did. (The car's an '06.)
It would be essentially impossible to flip the small, spring loaded, lift and rotate lever with road debris.
However, the valve does present a bigger target for debris than a plug. It's higher than the frame member and protected by it, so I'd say the odds of it being struck and snapped off are very slim.
Old Dec 9, 2007 | 12:50 PM
hulksdaddy's Avatar
hulksdaddy
Thanks Prof!
BTW, where did you get it?
Old Dec 9, 2007 | 12:55 PM
ProfMoriarty
Thanks Prof!
I ordered it (and the adapter) right from the company.
www.fumotousa.com
Old Dec 9, 2007 | 03:24 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Originally Posted by Sunnyvale Dave
I thought the drain plug was supposed to be put back in with a torque wrench.
It is...18 ft-ibs. You should still get an accurate torque reading even if you insist on using 3 feet of extensions.
Old Dec 9, 2007 | 03:32 PM
JmpnJckFlsh
Well, if that's the outlet of the fumoto valve pointed upward, I can't see your oil level getting any lower than the top of that outlet...looks like to me you're leaving at least a quart in the bottom of the pan. Or...maybe I just don't know how a fumoto valve works, and it drains out the bottom of the valve.
Old Dec 9, 2007 | 03:40 PM
9C1's Avatar
9C1
The oil comes out of the hole facing the camera. I have had several Fumoto valves on other cars, and they work well -- no road debris or accendential opening, and thye are very convenient. I wouldn't use it on the Corvette though. I value the magnetic plug, and I think it is important to find those needles from the rocker arms when they come out.
Old Dec 9, 2007 | 04:19 PM
humvet's Avatar
humvet
Have you actually seen metal fragments come out with the magnetic plug? I am thinking of getting one and was wondering if was a gimmick. Thanks!
Old Dec 9, 2007 | 04:21 PM
bluman's Avatar
bluman
Originally Posted by humvet
Did the reverse. Held the ratchet with the plug in the socket at a slight upward arc until I reached the oil pan. Like most mechanical operations, it then required a little finesse.
hopefully you wont strip it !
Old Dec 9, 2007 | 04:28 PM
9C1's Avatar
9C1
Not me -- only 477 miles on the car, so no oil change yet, however I have seen pictures on the site. The first change usually results in some "fuz" (for want of a better term) on the magnet(s). After that it is just to look for the needles.
Terry
Old Dec 9, 2007 | 08:09 PM
  #33
JmpnJckFlsh
Ahhhh!...of course; I should have known that. I agree with you...I don't like the idea that something could fail and cause my oil to drain out.
Old Dec 9, 2007 | 08:36 PM
  #34
RICH 28's Avatar
RICH 28
I just changed my oil last week. I position the car so that is half on the street and half in my driveway. There is a low spot between the street and my driveway. It gives me just enough room to get under the car to do the oil change. I even put a torpedo level on the bottom to make sure it's level to get all the oil out.
I learned this trick a while back from this forum.
Old Dec 9, 2007 | 09:06 PM
  #35
vettesmith02's Avatar
vettesmith02
Originally Posted by Hawk07
I bet when you cross thread it back on one of these times I'll hear you screaming all the way down here where I live...
That was my thought too.
Old Dec 9, 2007 | 09:55 PM
  #36
Ken07AOVert's Avatar
Ken07AOVert
St. Jude Donor '11-'12
Default theres a much easier way....
Just stand underneath the car.......it's so simple!
Old Dec 9, 2007 | 10:00 PM
  #37
Fcal's Avatar
Fcal
I just drive up on my Race Ramps. Why do all that reaching and stretching?
Chances are that when you drain the oil you're going to change the filter too. This way I get it all done in one shot.
To Remove Oil Plug Without Using a Jack!
Old Dec 9, 2007 | 10:50 PM
  #38
orca1946's Avatar
orca1946
Craftsman tools must like a lot
Old Dec 9, 2007 | 11:27 PM
  #39
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Beat me to it! Did mine this way this morning. No gorilla arms required
Terry
I had the typical ball of fuzz on mine at 1100 miles -- no fragments. I don't know about other years, but I was pleased to find my '08 had a magnetic plug from the factory. humvet, are you sure yours doesn't have a magnet already?
Old Dec 10, 2007 | 09:37 AM
  #40
ProfMoriarty
Huh?
