LS3 versus LS7 Engine Longevity
Old Dec 13, 2007 | 09:54 PM
Yule's Avatar
Yule
Default LS3 versus LS7 Engine Longevity
I have seen passing references to better engine longevity for the LS3 vs the LS7. Is this fact or fiction and if so the reasons why. Also, what type of mileage can one expect from a well maintained LS3 vs LS7?
Thanks,
Ken
Old Dec 13, 2007 | 09:59 PM
Cjunkie's Avatar
Cjunkie
the LS3 im sure.....the LS1,2,6 will have longer longevity than either one of those as well, for example the 1,2,3,6 all have the almost ideantical blocks the 1,6 have 3.9 bore, the 2 has 4.0 bore, and the 3 with a 4.060 bore. The 1,2,6 will have lighter pistons less stress and more 'meat' between the cylinder walls.
Old Dec 13, 2007 | 11:32 PM
shopdog's Avatar
shopdog
Thanks,
Ken
The big difference is that the truck derived LS3 has press in cylinder liners while the LS7 has cast in place liners. That means the LS3 block can be rebuilt, the LS7 must be discarded.
Old Dec 13, 2007 | 11:42 PM
BonestockZ06's Avatar
BonestockZ06
How can one know which will last longer when both of them are fairly new? One can make an educated guess, but no one really knows. I think this should be decided in the years to come when people start to put real miles on both engines. IMO, I think it's too early to tell.
Old Dec 13, 2007 | 11:45 PM
OregonC6's Avatar
OregonC6
wow, that's something I didn't know....I guess you couldn't bore the liners because the walls would be too thin....why couldn't they be machined out and replaced with press in?
A nonrebuildable block....is this a first for Corvette?
Old Dec 14, 2007 | 12:29 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Thats been long known. Yet another reason why you might not want to own this car out of warranty.
But then again, how many cars have you owned which had to have the engine block rebuilt?
Old Dec 14, 2007 | 09:34 AM
thetopdog's Avatar
thetopdog
I would assume that the higher redline of the LS7 could lead to lower longevitiy in the long run, but then again, who really cares? I'd take the LS7 over the LS2 in my car any day
Old Dec 14, 2007 | 12:47 PM
TLewis4095's Avatar
TLewis4095
Properly maintained all will go 250-300,000 miles before needing a total rebuild. These are not our fathers cars anymore.
Old Dec 14, 2007 | 05:55 PM
Yule's Avatar
Yule
Interesting factual comments. Thanks very much.
Ken
Old Dec 14, 2007 | 06:10 PM
AU N EGL's Avatar
AU N EGL
Dont abuse the engine and change the oil and these engines are almost indestructible.
As soon as OPEN up a create motor, all bets are off.
Old Dec 14, 2007 | 09:10 PM
PAmotorman's Avatar
PAmotorman
GM does 300,000 mile durability tests on all power trains now and that is why they can give a 100,000 mile warranty
Old Dec 14, 2007 | 10:34 PM
shopdog's Avatar
shopdog
Originally Posted by fafnir
you meant to say that the LS3 has the cast liners and the LS7 has the pressed liners - grey cast iron though - cheap useless stuff, check out darton ductile liners
_
No, I didn't mean to say that at all. I meant to say what I said. The LS1, LS6, LS2, and LS3 all use pressed in cast iron cylinder liners. All of these can be removed and replaced when they wear out. The LS7 has so little room between bores that the factory actually casts the liners in place rather than machining the raw blocks and pressing in separate liners the way they do for the other engines. Thus the LS7 block is a throwaway when it wears. Chevy has only ever made one other engine with a throwaway block, the infamous Chevy Vega engine.
Old Dec 14, 2007 | 10:45 PM
PAmotorman's Avatar
PAmotorman
the GMPP 2008 catalog list the LS-7 block part# 17802854 as having pressed in iron sleeves. the other LS engines have boreable cast in sleeves
Old Dec 14, 2007 | 10:49 PM
phileaglesfan's Avatar
phileaglesfan
With proper maintenance I don't see why either engine wouldn't last a life time. Both V-8s pretty much don't work hard in normal traffic or on the highway.
Old Dec 15, 2007 | 12:48 AM
Duck916's Avatar
Duck916
Was that intentional though? I though Reynolds sold them on an aluminum alloy that would have the durability of a cast iron block. As I recall, the Vega motors didn't use liners at all (at least not the first couple years of production).
Old Dec 15, 2007 | 01:39 AM
PAmotorman's Avatar
PAmotorman
the cylinder wall finish on the reynolds 390 alloy block was very very critical and in production GM never quite got it right and they used oil.a lot were sleeved with cast iron for the repair
Old Dec 15, 2007 | 09:16 PM
Yule's Avatar
Yule
Thanks for the answers.
Ken
To LS3 versus LS7 Engine Longevity
Old Dec 16, 2007 | 03:36 AM
WHT's Avatar
WHT
tomhenryracing.com
"The LS7 has its roots in motorsports--the four-time, 24-Hours-of-LeMans winning C5.R and C6.R Corvettes, to be exact. Its aluminum block is derived from the C5R Racing Block (PN 12480030, also available at THR) used by those road racing Vettes. LS7 is, also, related to the Generation 3 and 4 Small-Block V8 engine families used in the Corvette, Camaro and Chevy full-sized trucks, however, it differs from those production engines in certain areas.
First, it has pressed-in cylinder liners, rather than the cast-in-place liners of other Gen 3/4s. Those pressed-in liners have 104.8-mm bores rather than the 101.6-mm or smaller, bores of others. Its cylinder heads, also, have racing pedigree through a reduced, 12° valve angle rather than the 15° of other Gen 3/4 engines. The valve angle reduction improves airflow through the heads' intake ports. The intake manifold is, also, a unique part developed through the Corvette Racing program. LS7 has a dry-sump oiling system inspired by the dry-sumps used in racing and developed for the Z06's high lateral acceleration ability."
Old Dec 16, 2007 | 08:57 AM
PAmotorman's Avatar
PAmotorman
Originally Posted by WHT
tomhenryracing.com
the LS-7 has pressed in sleeves so the block can be serviced if a cylinder need repaired since the cylinder sleeve is too thin to be bored oversize. the other LS blocks have thicker cast in cylinder sleeves and can be bored oversize if needed for repair. to make big bore blocks from the non LS-7 blocks you bore out the cast in sleeves and install pressed in sleeves
Old Dec 16, 2007 | 09:22 AM
WHT's Avatar
WHT
That was my point.
The statement(s) that "the LS1, LS6, LS2, and LS3 all use pressed in cast iron cylinder liners while the LS7 has cast in place liners" is(are) not correct.
