Jacking Pucks
Old Dec 14, 2007 | 02:57 PM
User 020720's Avatar
User 020720
Originally Posted by oak3x
Are the Rectangular BMW Pucks removable? The rounds are permanent from what I understand
Even though they're designed for permanent installation they are both removable. The round ones are a little easier to take out.
The rectangular ones will take a little more elbow grease because of the tighter fit. You'll need a pair of pliers to remove the expansion pin and it helps to have a putty knife and a long flat bladed screwdriver to pry the tabs loose.
Old Dec 14, 2007 | 02:58 PM
bosco 08's Avatar
bosco 08
just ordered the eBay set $24.00 shipped.
eBay > jacking pucks and bag
Old Dec 14, 2007 | 03:48 PM
Victoryred 08's Avatar
Victoryred 08
St. Jude Donor '08
You can get them from Bravarian Auto Sports..."Bravauto.com" They fit our Vettes perfectly. Their Pt# is 51711960752. If I recall they cost $6.95 each.
Old Dec 14, 2007 | 04:07 PM
HawaiiC6's Avatar
HawaiiC6
Originally Posted by Wayne O
I've had good results using the rectangular BMW jacking pucks. I wouldn't want to use aluminum.
the rectangular over the round circular ones are the best, round BMW pucks fit into the cradle cup of my jack and will pull out at which time you will have to pry the puck out of the jacking cup. The rectangular ones give you more area to jack on. I installed mine and it makes it very easy to work on my car. Cost is about $7.99 @ piece.
Old Dec 14, 2007 | 07:52 PM
Modshack's Avatar
Modshack
Old Dec 15, 2007 | 03:08 PM
08C6Vert's Avatar
08C6Vert
Default eBay > jacking pucks and bag
DITTO...
Old Dec 15, 2007 | 03:12 PM
HawaiiC6's Avatar
HawaiiC6
Both are removable as they have hard plastic tabs to hold them in place but can be pried out. I like the rectangular ones as they give a wider jacking surface and won't get stuck in the jack's cup.
Old Dec 17, 2007 | 01:39 AM
EvilBoffin's Avatar
EvilBoffin
St. Jude Donor '09
Default Thanks for finding these on eBay, guys !!
Originally Posted by lguyot
DITTO...
eBay > jacking pucks & bag
Another DITTO here... Just bought this set. This guy has a perfect feedback record and sells these things constantly and exclusively for C5 & C6 Vettes, so they look like a winner.
Plus, I like the idea of the included storage bag to keep them together in a rear cubby, especially if they ever got grease or road tar on them from the underbody.
Old Dec 17, 2007 | 07:08 PM
Baad Z06's Avatar
Baad Z06
Does anybody know if these pucks on Ebay will work with a C6-Z06? The slot is deeper in the frame than the C5 or C6 and my aluminum pucks will not work + I would like to try the hard rubber ones. Thanks for any info.
Old Dec 17, 2007 | 07:21 PM
quickride's Avatar
quickride
There are feedback comments in the auction from ZO6 owners who have purchased these pucks and say they work on their cars. I know for a fact that these pucks worked on a 2005 ZO6. I don't think GM has changed the slots since then.
Old Dec 17, 2007 | 08:01 PM
Baad Z06's Avatar
Baad Z06
Do you mean 2006 Z06? No MY 2005 Z06 I am aware of. Thanks.
Old Dec 17, 2007 | 08:13 PM
timd38's Avatar
timd38
Originally Posted by johnodrake
I use BMW pads. 5 bucks each.
Ditto, cheap and the look like they were made for the car.
Old Dec 17, 2007 | 08:46 PM
  #33
quickride's Avatar
quickride
I wasn't referring to my (MY) car. I had a neighbor for a short time who had a silver ZO6 and I'm pretty sure it was an '05. I showed him my pucks and we test fit one of the pucks on his car. It fit on his the same way it fit on mine. He has since moved to Alabama because of his job.
Old Dec 17, 2007 | 08:51 PM
  #34
User 020720
They didn't make a Z06 in model year 2005.
The pucks I bought from Ecklers do not fit the Z06 as stated on their website, but they have ones that do. Unfortunately they appear to be temporarily out of stock.
http://www.ecklers.com/product.asp?p...6&dept_id=1098
Old Dec 17, 2007 | 09:05 PM
  #35
quickride's Avatar
quickride
You might be correct about this BUT it really doesn't matter if my neighbor's car is an '05 or an '06. It definitely is a ZO6. I stand corrected.
Old Dec 17, 2007 | 11:30 PM
  #36
cee6's Avatar
cee6
Default jacking pucks
would anyone have the address for the jacking pucks & bag from EBay all my search turned up was for the aluminum ones. thanks in advance
Old Dec 17, 2007 | 11:50 PM
  #37
bosco 08's Avatar
bosco 08
just received my set today, they are hockey pucks with a eye hook very well done btw and the bag is good. not having to run around hunting the parts alone make's this a good deal. will try them tomorrow and report back.
use the eBay search window and type in jacking pucks and bag will take you right to it
To Jacking Pucks
Old Dec 17, 2007 | 11:59 PM
  #38
cee6's Avatar
cee6
thanks . I'll give it another shot:o
Old Dec 18, 2007 | 12:12 AM
  #39
bosco 08's Avatar
bosco 08
i just tried it and it works for me.
Old Dec 18, 2007 | 01:22 AM
  #40
EvilBoffin's Avatar
EvilBoffin
St. Jude Donor '09
cee6 -
I replied to your email, but for other members' reference, here's the description the seller uses for his eBay ads for these pucks :
CORVETTE C5 C6 JACK JACKING LIFT PADS PUCKS & BAG * *
So searching for either his seller ID savonic or just "JACKING PUCKS & BAG" should do the trick.
Also, he Priority Shipped within hours of my purchase, then sent an email with tracking info and a PICTURE of the package as it was ready to ship! That's good service in my book ...
