Need some help
Old Dec 14, 2007 | 02:11 PM
chevyc6z51's Avatar
chevyc6z51
Default Need some help
This is a dumb question but i cant get the key to come out of my 08 fob how do you do it????
Old Dec 14, 2007 | 02:16 PM
CQRT's Avatar
CQRT
Hopefully the same as the `07 reference in the Owner's manual . . push button "A"
here's the link to the Owner's manual in the FAQ's:
https://www.mygmlink.com/pdf/go2cont...07corvette.pdf
Old Dec 14, 2007 | 02:27 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Never even knew there was a key in there, lol.
Old Dec 14, 2007 | 03:24 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
From the "Getting to Know Your 2008 Corvette" Supplement:
Master Key
The master key
is stored inside
the Keyless
Access
transmitter. To
remove the
master key, push
the small button
near the bottom
end of the transmitter and pull out the
key.
See Section 2 of your Owner Manual.
Old Dec 14, 2007 | 03:27 PM
logansrun's Avatar
logansrun
Blue on Black
Just hard to get out keep pulling
Old Dec 14, 2007 | 03:29 PM
Modshack's Avatar
Modshack
Yup...Takes a pretty good yank..
Old Dec 15, 2007 | 05:54 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
See page 2-4 of your manual:
To remove the key, press
the button (A) near the
bottom of the keyless
access transmitter, and
pull the key out. Never pull
the key out without
pressing the button.
Old Dec 15, 2007 | 06:08 AM
rws.1's Avatar
rws.1
The button is not obvious.
it is chrome plated and could easiliy be confused as decoration and not a button.
Look closely at the picture in the first post. At the bottom of the fob ( end opposite the lock unlock buttons) you will notice a slot in the top plastic cover. The button that needs to be depressed in a chrome plated locking tab ththat prtrudes from the base of hte key and locking into that slot in the cover.
Rather than calling it a button perhaps thay should have said depress locking tab...
Old Dec 15, 2007 | 06:40 AM
VettinFan's Avatar
VettinFan
Just keep pushing down on the chrome button while doing so. A few members broke the FOB pulling without pushing. It does take a bit of effort, but it will open.
~AL~
Old Dec 15, 2007 | 08:13 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
that little button is tough. when you do get the key out, repeat it about a dozen times and the "latch" or button will loosen up a bit and release the key much, much easier. from experience on both my fobs.
Old Dec 15, 2007 | 08:19 AM
2vette2's Avatar
2vette2
Veteran: National Guard
St. Jude 15 Year Donor
St. Jude Donor '09-'25
I actually went back to the dealer and even he had a tough time. Just push the button and pull. It will appear.
Old Dec 16, 2007 | 05:12 AM
chevyc6z51's Avatar
chevyc6z51
Thanks for the help i no were the botton is. Do you feel a click when the botton is all the way down???? I just dont want to f-it up!!
Old Dec 16, 2007 | 08:03 AM
foremaw's Avatar
foremaw
No, no click, just make sure its depressed. As stated above, once you get it out, work it a few times and it gets a little looser. However, you want it to stay kinda tight, wouldn't want to lose that key.
To Need some help
