run flat patch
Old Dec 18, 2007 | 10:51 AM
agrumpyguy's Avatar
agrumpyguy
Default run flat patch
Had patch and plug in rear runflat 9000 miles and now losing 1lb a week.
Is it possible to re patch a patch?
Old Dec 18, 2007 | 10:54 AM
Walt White Coupe's Avatar
Walt White Coupe
I don't know if you can. You should first determine if the patch is the leak with some soapy water or spit and look for bubbles.
Old Dec 18, 2007 | 11:05 AM
ZO6Gal's Avatar
ZO6Gal
I got a nail in mine and the shop told me that it is now illegal to patch a runflat. Since I knew I that I was not going to go with runflats again, i went ahead and bit the bullet and ordered BFG NT's. They should arrive at the end of the week. If I were you, I wouldn't take a chance.
Old Dec 18, 2007 | 12:01 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
That's not true.
Old Dec 18, 2007 | 12:04 PM
TLewis4095's Avatar
TLewis4095
Run flats can be patched, not plugged (although they do fine w/a plug). Only some ins carriers don't allow it.
We have like new 19" runflats in stock for $100 each if you need a spare (it will need a patch as these all have a nail or screw in the tread)
Old Dec 18, 2007 | 12:33 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by Corvette Junkie
That's not true.
Total
Old Dec 18, 2007 | 12:35 PM
johnodrake's Avatar
johnodrake
Moderator
Actually, it is both. The patch with an integral plug is inserted from the inside with the plug being pulled through the hole
Old Dec 18, 2007 | 12:41 PM
TLewis4095's Avatar
TLewis4095
You are correct, the patch has an integrated plug. Just the plug alone is not permitted by most ins carriers (shop liability).
Old Dec 18, 2007 | 12:49 PM
HawaiiC6's Avatar
HawaiiC6
I just picked up a roofing nail and it was on a Sunday where all repair shops were closed. Since I had a plug kit which I have for conventional tires, I plugged the GY run-flats, I took the car out on a cruise and even did a high speed run with no problems.
It is correct that due to liability some tire shops just flatly refuse to fix a flat tire.
Old Dec 18, 2007 | 12:54 PM
johnodrake's Avatar
johnodrake
Moderator
That may be true as their reason, but Run Flat GY's can be repaired and retain the speed rating (one repair) per the GY website. I have had two tires repaired with no issues - both done at GY shops. If I were in your position, I would take my "temporarily repaired" tire to GY and have it fixed right - under warranty if the tire is < 1 year old.
Old Dec 18, 2007 | 12:55 PM
entwood's Avatar
entwood
Old Dec 18, 2007 | 01:13 PM
HawaiiC6's Avatar
HawaiiC6
Past 1 year (June) tire with only 7800 miles on them. I removed the tire checked the plug no leaking, will keep monitoring. Tire held up at 160 mph.
Once the rear tires wear out I will be switching to conventional tires.
Old Dec 18, 2007 | 01:27 PM
VET4LES's Avatar
VET4LES
I got a nail in mine and the shop told me that it is now illegal to patch a runflat. :
Old Dec 18, 2007 | 04:23 PM
Painrace's Avatar
Painrace
Buy a NAPA Tire Repair Kit #710-1028 and plug the tire youself. I have plugged road race tires with it and driven them up to 210 MPH. I have a plug in one of my rear C6Z tires now that has been in for about 6,000 miles. The kit has a gun in it and a mushroom plug so the air in the tire seals the plug. The gun puts the plug into the tire and when you pull the gun out the plug stays in. Cut as much rubber off of the plug as you can and you are ready to air up and go!
Old Dec 18, 2007 | 07:21 PM
rz2mbc's Avatar
rz2mbc
I have had 2 different incidents on the same tire...local GY store did a excellent job with both plug/patch repairs. Both under GY warrant, total cost $ 0 !!
Old Dec 18, 2007 | 07:47 PM
HawaiiC6's Avatar
HawaiiC6
Buy a plug repair kit for less then $10.00 and as long as you have an air compressor you are good for most tire repairs, unless it is sidewall damage.
Without that kit my car would have been down for over a day and then be at the mercy of GY.
To run flat patch
