Will a partition help decrease interior resonance?
Old Jan 12, 2008 | 10:03 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Default Will a partition help decrease interior resonance?
I would assume no, but just thought I'd ask.
Old Jan 12, 2008 | 10:14 AM
JLMounce's Avatar
JLMounce
Not anything measurable.
The partition could act as a diffusion panel which is used in studios to regulate sound waves, but 1 isn't going to do crap for you.
You're best bet if it bothers you is to do an insulation kit.
Old Jan 12, 2008 | 10:18 AM
03 Z-oh-6's Avatar
03 Z-oh-6
That's what I figured.
Old Jan 12, 2008 | 10:19 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
only the insulation kit will or some other sound deading mat will.
Old Jan 12, 2008 | 01:32 PM
SoCal Rob's Avatar
SoCal Rob
Are you asking about the air pressure resonance that occurs when the roof panel is removed or mechanical/exhaust resonance? Just trying to learn. Thanks.
-Rob
Old Jan 12, 2008 | 02:16 PM
Pipedreams's Avatar
Pipedreams
-Rob
exhaust
Old Jan 12, 2008 | 02:26 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Originally Posted by Pipedreams
exhaust
You know me to well.
Actually, I put the Route 66's back on today with the stock X pipe, the resonance is gone. I love the Route 66's(no drone), but they're a bit to quiet! They'll hold me over for a while, though.
Old Jan 12, 2008 | 03:16 PM
maxp's Avatar
maxp
a little off topic but it seems to me that adding the partition has improved the sound of the bose in my C6.
Old Jan 12, 2008 | 03:21 PM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Ive heard that from several people myself. The partition blocks most of the sound waves (from the rear speakers) from going back into the hatch. They also say its helps but does not eliminate the wind buffeting.
The one from EXOTICVETTE.com gets the most votes and the roof can be stored without its removal.
Old Jan 12, 2008 | 03:55 PM
maxp's Avatar
maxp
that is the one I have, it gets another vote
Old Jan 12, 2008 | 05:16 PM
Gold Z's Avatar
Gold Z
Veteran: Marine Corps
I love my partition. I'm always carrying things that I just throw in the partitioned off area and when I need them they are right at arms length. Super handy for coats and caps and such. There is no change in exhaust resonance. It may be my imagination but the stereo seems to sound a little better.
Old Jan 12, 2008 | 05:44 PM
loubob57's Avatar
loubob57
Will the partition help with the win buffeting through the passenger window? The one that makes the passenger seat belt flap around unless you raise the window a couple of inches?
Old Jan 13, 2008 | 10:07 AM
hd1989's Avatar
hd1989
does the Exoticvette partition fit in place with a cargo mat or is the mat too thick
Old Jan 13, 2008 | 04:24 PM
LMB 4 ME's Avatar
LMB 4 ME
Good question....I will soon be getting a cargo mat myself
Old Jan 13, 2008 | 05:01 PM
EvilBoffin's Avatar
EvilBoffin
St. Jude Donor '09
There are some REPORTS that it will help buffeting, though it's been too cold here since I got my partition to remove my top long enough to confirm that personally.
However, some other posts have suggested that you can significantly decrease buffeting if you only lower one or both windows 1.5 inches from fully closed. Fully closed or fully open apparently makes the buffeting worse. Again, I can't confirm this theory yet...
As shown on the Exoticvette website, it will work fine with a cargo mat. The extra 'tail' section of carpet can then be tucked under the mat or all the way under the OEM carpet - either way you like it.
Old Jan 13, 2008 | 05:03 PM
LMB 4 ME's Avatar
LMB 4 ME
Hey great! Thanks for the info
Old Jan 13, 2008 | 05:15 PM
VET4LES's Avatar
VET4LES
I found that mine reduced road noise and improved the sound of the rear speakers.
Old Jan 13, 2008 | 05:22 PM
Swiftrider08's Avatar
Swiftrider08
Fits just fine with Lloyd's cargo mat. Tuck front of partition carpet under the cargo mat or factory carpet. Tuck the ends of the partition carpet up and under the speaker grills. Looks like a factory intall and the Exotic Vettes partition can stay in place when the top is stored in the back.
To Will a partition help decrease interior resonance?
