Please Explain!!!!!!!!
Old Jan 14, 2008 | 07:24 AM
ljm22's Avatar
ljm22
Default Please Explain!!!!!!!!
Im the new owner of my first vette, 2007/c6/A4 with paddels. Can the npp be put on my car? Do you use this feature on stock exhaust? Thanks guys. Also just wanted to say Thanks to all as Im asking alot of questions lately and everybody has been very informative and helpful. Thanks again. Lee
Old Jan 14, 2008 | 07:50 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Here is a full install below on a 2005. I developed a product called NPP in a box the only available self contained system to run either the GM NPP or Z06 bi-mode systems. It eliminates the cost and problems in trying to install all the GM parts needed to operate the system. It’s available on www.nakidparts.com
Here is a repost of Craigster05 post in the tech section
Originally Posted by craigster05
Ed’s NPP in a box, a set of NPP mufflers and a M2W switch will give you an incredibly easy way to have just the sound you want, when you want, if you have a pre-2008 C6. In my case, throw in a set of headers, and you have rolling thunder at the flick of a switch. The combo of the headers and the NPP in Wild gives you AMAZING sound and “HEY, LOOK AT ME!!!” volume…the tonality and sound is that of a NASCAR stock car at WOT outside the car, yet quieter and less drone inside the car than the GHL exhaust I was so fond of. The install is very straight forward, easier with a lift, but as Ed has shown with his car, you can do it on jack stands. Here are some pics and descriptions of the step by step process; you will receive complete illustrated instructions with your purchase.
NPP Mufflers waiting for Install
Factory Exhaust Removed
Drilling a ¼” hole in the rear well
Run the Vacuum Tube though the hole
Run the Vacuum tubes through existing frame locations
After dropping the rear sway bar, snake the NPP mufflers up and over
Attach the pipes to the mufflers
Connect the vacuum hoses to the NPP mufflers
Make sure your muffler pipes are straight and level
Muffler hardware done and vacuum tubing run
Locate vacuum nipple in well
Place NPP controller in bottom and attach vacuum and power lines
Place lid on top, you can still store items here (Does that look perfect or what???)
Connect power cable to the Seat Heater Fuse
And of course, a quick run with Ed's Polishing kit
That's all there is to it.....All that's left is to go out there and have a blast with your new found customized sound.
Old Jan 14, 2008 | 07:56 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
This does make a nice installation.
Old Jan 14, 2008 | 08:10 AM
VetteManRay's Avatar
VetteManRay
From: Forest Hill, (Out in the country), north of Baltimore. Maryland. Land of "Pleasant Living" with my Corvette, steamed crabs & crab cakes.
Default A Big “HELLO” from Forest Hill, Maryland
Thanks for sharing
Old Jan 14, 2008 | 08:17 AM
ljm22's Avatar
ljm22
Thats why this forum is great. Thanks alot
Old Jan 14, 2008 | 08:44 AM
silver-surfer's Avatar
silver-surfer
Just did the NPP and NPP in a box mod to my 07 A6 vert. I could not be more happy. Best of both worlds. Loud when I want and quiet when I need it to be a good neighbor.
Old Jan 14, 2008 | 08:58 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I agree NPP sounds a little better than the limp sounding stock exhaust (at least when it kicks-in) but IMO you're better off going with a quality, after-market exhaust such as Corsa or Borla. They look better; sound better; the small performance gain is comparable; and, they work on a full time basis.
I give credit to our excellent forum vendors like Pipedreams that recognize the demand...Corvette owners want to 'fix' the Corvette exhaust...both the stock exhaust and the NPP exhaust.
Everyone has to find the solution they like best. I offer my opinion merely as food for thought. Good luck whichever way you go.
Old Jan 14, 2008 | 09:23 AM
Pipedreams's Avatar
Pipedreams
Actually I forgot the video of the system. I know many point to the aftermarket systems but honestly once you listen to this (only recorded on a cheap still camera) you will be hard pressed to find an after market exhaust this aggressive but yet with the press of a button be stock quite. But just like colors everyone has their own opinions. I had the B&B route 66 and wished for something more aggressive but did not want it loud all the time, these fit the bill. The tips are not as nice as the B&B but close
PLAY VIDEO - TURN UP THE SOUND
Old Jan 14, 2008 | 10:40 AM
fright88's Avatar
fright88
Just an fyi if it is a 07 it has an A6 not A4
Old Jan 14, 2008 | 02:09 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Jan 14, 2008 | 03:19 PM
chet b's Avatar
chet b
Old Jan 20, 2008 | 05:44 PM
Hogvette's Avatar
Hogvette
Wanting to do this to my vert as well, but haven't found any details on the vert installation...where did you put the M2W box? how did you route power cable from there to fuse box? Thanks for any information you can share...
Old Jan 20, 2008 | 07:21 PM
Pipedreams's Avatar
Pipedreams
I am the only one currently selling this system and was the first to develop it. All the instructions are on my site and the vert install is the same. I have sold almost 50 and 20% have been verts
www.nakidparts.com
Old Jan 21, 2008 | 08:18 AM
silver-surfer
Hogvette I sent you an email. The install of the box and power cord is quite easy. If you have ONstar it is a little more fo a pain but Ed's instructions pretty much cover it.
Old Jan 21, 2008 | 08:51 AM
Sven's Avatar
Sven
St. Jude Donor '08-'09
One of the best tech threads! Maybe docrings can add to his FAQs sticky ...
To Please Explain!!!!!!!!
