Highbeam help
Also another newbie question, how do I program the car to make it say what I want at start up?
Are there any other cool little things like that??? I don't have a book on the car so I'm relying on searching the forums.
I saw that lowering the car is super easy... maybe some more mods like this too???
Sorry for the newbie questions
https://www.mygmlink.com/pdf/go2cont...05corvette.pdf
Also, would you please fill in your profile so folks will know a little about you and your car? It can make a difference in the quality of help you get in the future. Thanks.
Headlamp High/Low-Beam Changer
To change the headlamps from low beam to high,
push the turn signal lever all the way forward. To change
from high to low beam, pull the lever rearward.
While the high beams
are on, this light on the
instrument panel cluster
will also be lit.
Flash-to-Pass
To use the flash-to-pass feature, briefly pull the turn
signal lever toward you. The high-beam indicator flashes
to indicate to the other driver that you intend to pass.
If the low-beam headlamps are off and the fog lamps are
on, the fog lamps flash.
will also be lit.
Flash-to-Pass
