Splash guards????
Old Feb 14, 2008 | 11:28 PM
Volocty's Avatar
Volocty
Originally Posted by mickeykelley
Are the splash guards worth it? Any pics to see how it changes appearance. Thanks
I bought the stock Flares for a Z06 and with a little imagination they were on. I really like the molded look.
Old Feb 14, 2008 | 11:38 PM
cthusker's Avatar
cthusker
Originally Posted by Gordon Shumway
OK, I have to play devil's advocate here. In all of these splash guard threads one of the most prevailing type comments is:
"Put them on as soon as I got the Vette. They work great, and saved my paint."
How exactly does one know it saved the paint? Or put another way, how do you know the paint wouldn't look the same if they were never installed? It's obvious a lot of you aren't willing to take the chance, but it is food for thought.
I haven't decided yet whether to use them when my car gets here, but the self-fulfilling prophecy argument isn't helping the decision.
cadguymark had an excellent observation above on the angle of the photos. I have seen some pictures from the other angle, and they are kind of nasty looking.
I'd say a lot depends on the kind of roads you drive on. In New England with the sand/small gravel that put down over the winter I guarantee you will destroy the paint on the bottom half of your panels. Been there done that on several cars. Yea sure you can go out and have them repainted once a year if it bothers you. For me the choice was easy. I wanted to keep my vette for awhile and keep it looking as good as possible. Without some type of protection the stuff on these roads will sand blast those fender panels in very few miles. My 06 still looks brand new on the bottom side of my fenders so I made the right choice for me....
Old Feb 15, 2008 | 07:05 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
looks great, I sell the front only for guys like you
Old Feb 15, 2008 | 08:56 AM
mickeykelley's Avatar
mickeykelley
How much imagination? Any cutting or what? About how long to install?
Old Feb 15, 2008 | 01:45 PM
Volocty's Avatar
Volocty
No cutting on the car. I just removed all of the braces and plastic supports on the inside of the Flare (which would have been needed to install on a Z06). I used an exacto blade and a screwdriver, were needed. This gives the Flare a little more flex (so it can contour to the std C6). Once all the inside flare support is gone, I just cleaned up the fender edge (to allow the ahesive tape on the flare to stick), removed two existing screws on the bottom of the fender (take a look and you will see what I mean), attached the Flare on the bottom and then just pushed the Flare against the fender to make it a snug fit. The installation did require me to use 1 self-threading screw on the inside of the wheel-well (this is the most IMPORTANT step). I had to push and hold the Flare up against the fender to make sure it was tight, then put the scew in. The stock Flare does not come with the "Top Clip", so you need to buy 2 of those too. (that secures the skinny edge of the Flare to the top of the Wheel-well). The first side took me about an hour, while I figured out what to remove from the inside of the Flare, (which also included fighting my nervs!), the second side took me 15 mins. Here are a couple of other pics. (and I do love the way they came out).
Old Feb 15, 2008 | 03:52 PM
mickeykelley
Did you ever consider painting them body color? I like the look of your molded style too. It looks more factory and not just a generic addon. So many cars have come with them body color, it might really look good that way.
Old Feb 15, 2008 | 05:20 PM
Raysfins's Avatar
Raysfins
I went with the molded guards from Alltec. You can get them at many of the vette product vendors.
Old Feb 15, 2008 | 07:05 PM
autox c6's Avatar
autox c6
What are the part numbers for those Z06 rear splash guards?
Old Feb 15, 2008 | 09:00 PM
Volocty's Avatar
Volocty
PN- 15818636 & 15818637 (Left & Right) List price is $48.51 (ea)
Also you need the 2 retainer clips that go on the very top of the Flare (1 for each side) PN-15895394 List price is $3.39 (ea)
(All parts were for a 2007 Z06)
Old Feb 15, 2008 | 09:21 PM
autox c6's Avatar
autox c6
Thanks. But I can't find the 15895394 clip. I'm looking on gmpartsdirect.com. Can you double check the number maybe?
Thanks.
Old Feb 18, 2008 | 11:36 AM
Volocty's Avatar
Volocty
Thanks.
That is the number that was on my invoice, it might just be one of those little items you have to get at the Dealer.
Old Feb 18, 2008 | 12:43 PM
autox c6's Avatar
autox c6
No worries. Thanks for your help. By the way, do you have any additional pictures showing how much material you removed and where? Anything else you can share will help me avoid figuring out something that's already been figured out.
Old Feb 18, 2008 | 03:29 PM
  #33
Just 4 2's Avatar
Just 4 2
I did aspis and they look pretty good. they blend into the fender real nice.
Old Feb 18, 2008 | 04:22 PM
  #34
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Not for me.
Old Feb 19, 2008 | 11:09 AM
  #35
Volocty's Avatar
Volocty
I don't have any more pictures than what I shared above in this Post, but I can say you just want to remove ALL of the support braces and metal (held on by tape) hangers on the "inside" of the Flare/Modling. I used a dremmel tool first, but found an Exacto knife worked better when I did the second Flare.
Old Feb 19, 2008 | 11:20 AM
  #36
jimchris76's Avatar
jimchris76
I think they look good and may do the same thing. I also have yellow.
