What is the purpose of drilled rotors? I know that they shave off some rotation mass from the wheels, but is there any other reason? It seems like the edges of the drillings would shave off the brake pads. I'm also thinking that with less mass, that the rotors would disapate less heat during hard braking.
whether it's still valid or not, drilled rotors used to have the purpose of getting rid of built up gases from the friction of the pads against the rotors. that may not be necessary today. but as you said, there is the cool-look factor.
The holes are chamfered to avoid the "cheese grating" factor on your pads. The holes are supposed to increase cooling. For street use it's likely all cosmetic.
I must say though that I like the look!
Thanx
Yep..................mostly cosmetic tho for actual applications where an advantage is sought( call that RACING), possible lighter weight, higher heet disipation rather than absorbtion would be the consideration factors. On the street....I just like the look!
You're correct about the cool factor...according to the 'Godfather' of the C6 (Dave Hill), the drilled rotors were used "just for looks" to give the car a "racier" appearance. Despite the cool factor, quite-a-few guys have had problems with the drilled rotors cracking with track use...they most often switch to slotted rotors.
Thanx
That's funny, I used to think the same exact thing about the holes slicing up the pads... But they don't. The Z51 rotors are "Mostly" for looks, they are somewhat effective. The Z51 rotors really should have been Crossed Drilled & Slotted for full functionality, or so I've been told.
The drilled holes do help with the temps though, they look great & they do stop slightly better due to there larger size vs stock. Overall it's still a great braking system I.M.O I just wish they were slotted too.
The REAL "drilled" rotors are cast that way - NOT drilled. I believe this is a Porsche "invention", may be wrong.
The rotors lose their strength when drilled and this can lead to cracking and other issues. Slotted is the way to go unless the holes are built into the cast.
Actually, it may be that solid rotors , big ones , are better than slotted or drilled or a combination of both for real racing applications. I guess a person would have to look at real race cars up close....you know the kind that have millions or tens of millions of dollars invested in them....to know the truth.
That Z51 option rotors stop the C6 any better than the base car solid rotors, or perform any better with regard to heat on the track is not something that I recall ever having seen tested. Everyone says the holes improve performance, and the Z51 option rotors are a bit larger ....but the proof of the assertions is not easy to find....just the claims.
The interested will notice that the Z51 option and the Z06 model both share basically the same kind of rotors and rotor technology....that is, in a word, OLD. They are both full of holes, both cast iron, both one piece, and both HEAVY. The Z06 rotors are larger. Now cast an eye at the ZR1 and you'll see a very significant departure from the old approach in the form of the carbon fiber rotors.
Just about to become a Corvette owner. I thought about the Z51 package, but finally decided against it.
I road race and have other cars to track.
Anyway, drilled rotors are bling.
GM did a test, and I read the SAE paper on it, that holes still have some relevance today, and in the test they did, but at the expense of 2 times shorter rotor and pad life. The test was very nebulous and did not use stopping distances or any other data that a non-engineer could quantify. It said their biggest advantage was in wet conditions.
For the street it’s a non-issue really, but for HPDE events where high heat is sustained solid or slotted is the way to go with today’s pads. The short rotor life on the track is not worth any "potential" benefit that "holy" rotors still have.
Drilled vs. cast, it doesn't make much difference in rotor life.
Drilled rotors are only for looks. If you tried to race them, they'd crack very quickly. If you want real racing rotors, go slotted or, even better, carbon (lots of $$, though).
