Air Compressor Question
Old Feb 21, 2008 | 09:36 AM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Default Air Compressor Question
Can anyone recommend a good air compressor for the garage? I need it to keep up with tire pressure, blow dust off the car, etc. I'm not looking for a commercial unit, just something to use at home. I bought and returned a Husky 1.5 gal unit that I wasn't happy with. I'm also trying to stay away from 12Volt models. Thanks
Old Feb 21, 2008 | 09:46 AM
nmerhaut's Avatar
nmerhaut
I think Sears and Craftsman makes some good ones.
Old Feb 21, 2008 | 09:47 AM
jnx911's Avatar
jnx911
You can go to Home Depot and get one of their upright models with a 50-60 gal. tank. They run $500-$600 and will last you forever. I wouldn't get anything less. Another place to look is Sears, they have a nice selection.
Old Feb 21, 2008 | 10:00 AM
PappyTinker's Avatar
PappyTinker
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
I have a Campbell-Hausefield 2 1/2 gal unit that I got at Home Depot that I use for my air tools. It is on wheels and quite convenient. I would suggest also getting an air tank. I use that to fill tires instead of pulling the compressor all over the place.
Old Feb 21, 2008 | 10:07 AM
08Roadster's Avatar
08Roadster
Old Feb 21, 2008 | 10:14 AM
BearCreekC6's Avatar
BearCreekC6
I've had a DeVilbiss 2.5 gallon unit for several years and it's been very reliable. It works on my nail gun but isn't too big.
Old Feb 21, 2008 | 10:52 AM
Larry B.'s Avatar
Larry B.
This comes up alot, but no one ever mentions the noise. The old piston type are much quieter than the "oilless" or diaphram units that are common today although the piston type are still available. So if you have neighbors within a block or so stay away from those oilless units. They are also very annoying running in your work area.
Old Feb 21, 2008 | 11:03 AM
mksz51's Avatar
mksz51
IF you think you're ever going to use an air tools (especially an impact wrench or any kind of body tools) the smaller compressors will never work. They just can't supply the volume these tools require. IF all you want to do is inflate tires about anything will work. I have an upright 27 gallon - only downside is it is noisy as others have pointed out. Works great for a broad range of uses, however. "Commercial level" stuff is really nice but you need to be realistic on how often you will use it and how much room it will take over in your garage.
Old Feb 21, 2008 | 11:13 AM
User 020720's Avatar
User 020720
I have the Craftsman 2 gal that has a 1 hp oil lubed motor. It's been my experience the oiless units run much louder. My Craftsman is very quiet and it's portable enough that it sits on a shelf.
I got it on sale and so far it's been a very reliable unit. My only gripe was the accessory kit had a lousy hose so I bought a better one. I then purchased an Intercomp Racing fill/bleed/read tire gauge.
Old Feb 21, 2008 | 01:33 PM
2008c6's Avatar
2008c6
bought mine at sears. Craftsman 15 gallon upright tank. Small enough to move around yet enough capacity to handle medium to large jobs. (impact wrench, nail guns, etc,) Watch for sales and you can get some great prices.
I also bought the 100" rubber air hose. You can do a lot of jobs in the garage without moving the tank.
One note though. I ended up putting the compressor on a single circuit. My shop has a window AC unit and a Ice box/freezer . In the summer with all this running it kept tripping the breaker.
Old Feb 21, 2008 | 01:41 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
This would be perfect, I just got one for that reason.
Porta cable $164 Lowes
Old Feb 21, 2008 | 01:58 PM
MaxOctane's Avatar
MaxOctane
A lot of good suggestions here...
However I wouldn't get your hopes up to use it to blow dirt off of your car. The dust and dirt just won't "fly" off of the car and in order to get any significant results you would have to hold the nozzle so close to the car it would take you forever to do the whole car - and you would need a 500 gallon tank.
Perhaps with Rejex maybe? I've never used Rejex so I wouldn't know. Anybody out there tried?
Old Feb 21, 2008 | 03:34 PM
User 020720
Not a chance even with Rejex. After a few days worth of dust I could put my black C6 in a wind tunnel and it won't make a bit of difference.
My compressor is barely able to blow all the dust out of my home computer. Maybe I should spread some Rejex on those parts.
Old Feb 21, 2008 | 03:50 PM
ronsc1985's Avatar
ronsc1985
The first thing you have to decide is if you are willing to install 220 volt service in your garage. All decent compressors require 220. If you are limited to 120 the choice is severely limited to lower cfm (cubic feet per minute) models.
I never knew anyone who once they bought a compressor and saw how useful it was for many things besides your car, didn't wish they had got at least a 60 gallon tank, 15-20 cfm model. Nothing is more a PITA then running your fine air tool cutting something and having your compressor unable to keep up with the required air flow or spraying and seeing your spray pattern go to shyt because the compressor is losing tank pressure.
I'd stay away from the oil free types. They make a real racket and wear out the rings rapidly if you use them at all. Their is no filter on the incoming air into the cylinders and any particles in the air get into the cylinders and chew up the cylinder walls and the rings.
Old Feb 21, 2008 | 03:52 PM
rjavett's Avatar
rjavett
Sears has them on sale online. We have an upright medium size compressor and it has worked great for years.
http://www.sears.com/shc/s/p_10153_1...+%26+Air+Tools
Old Feb 21, 2008 | 03:54 PM
lemans 07's Avatar
lemans 07
I have a craftsman 'old school' compressor with a divorced compressor and electric motor connected via belt drive. It is super quiet and is 27 years old. It has had zero problems and it was actually a hand me down from my father. 20 gal tank and it has enough scfm to supply an impact or air ratchet all day long (twin cylinder compressor)
Whatever you decide on, be sure you drain the tank every time. I personally would recommend a divorced compressor as opposed to the oilfree noisemakers. I had one and GAVE it away because it was deafening to operate it in the garage and took forever to pump up to 110 psi.
It is always better to have too much than not enough
Old Feb 21, 2008 | 04:07 PM
C8-Vette's Avatar
C8-Vette
Get one that is belt driven . The oilless compressors are very noisey and have a much shorter life than the belt driven with a crankcase.
To Air Compressor Question
Old Feb 21, 2008 | 04:12 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I use a Craftsman 33 Gallon Compressor and it does the job fine. It is rated at 150 psi and I use it for tire rotations, pnuematic tools, blow guns etc. I believe is was $300.
Old Feb 21, 2008 | 04:27 PM
Wayne O's Avatar
Wayne O
CF Senior Member
If you just want to fill up your tires you can buy a portable tire pump at Sears for $30-$50. I've got one I use at the track with a contained (and removable) digital gauge that works quite well. I can set the pressure I want and it stops when it gets there.
If you want a decent home/shop model I suggest you get one with enough capacity to drive an impact wrench and other tools. The cost isn't that much more to buy one that 'does it all.' That's much better than buying one only to discover later on it can't do everything you want it to.
Old Feb 21, 2008 | 04:35 PM
loubob57's Avatar
loubob57
I have a craftsman 20 gal. model with the dreaded oiless diaphragm compressor. Yeah, it makes a racket while it's running, but once the tank gets up to pressure (60 is enough for tire filling) you can just shut it off. I got it on sale almost 20 years ago. I was intending to get a much smaller one but the sale was too good to pass up. It runs a paint spray gun just fine too.
