Help!Outside temp reading wrong
Old Mar 3, 2008 | 01:39 PM
nmerhaut's Avatar
nmerhaut
Default Help!Outside temp reading wrong
Fired up the '08 today for the 3rd time since Nov.and ran it around until oil came up to temp but noticed the ambient outside temp read 39 degrees. It's 68 in Cleveland and wondered if any one else has experienced this? Outside of this minor annoyance, everything looked and sounded great. Until the cold and snow dumps on us again.
Old Mar 3, 2008 | 01:51 PM
Swiftrider08's Avatar
Swiftrider08
You need to break at the owners manual for this one. The information is there explaining what and when the outside temp gage reads. In just general terms I believe the ouside temp will show what was there the last time the car was turned off. You have to drive it at/above a certain speed for a set amount of time before the temp will update. All has to do with the climate control system. Again, read the manual for info on this.
Found this info of page 3-29:
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 12 mph (19 km/h) for
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation.
There is also an inside temperature sensor located to
the left of the ignition switch. The automatic climate
control system uses this sensor to receive information,
so if you block or cover it, the system will not function
properly.
C6ToGo's Avatar
C6ToGo
do a search. I think the owner's manual even addresses this.
Old Mar 3, 2008 | 01:53 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
From the 2008 Owner's Manual:
Old Mar 3, 2008 | 02:05 PM
nmerhaut's Avatar
nmerhaut
Thank you all. I usually do read the manual but got busy with something else. Thanks again.
Old Mar 3, 2008 | 02:10 PM
dvilin's Avatar
dvilin
I believe this covers it.
five minutes.
properly.
Old Mar 3, 2008 | 02:41 PM
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
Times are changing.
People used to say, it's the American way to read the instructions when all else fails.
Now, all we have to do is post the question at Corvetteforum!
Old Mar 3, 2008 | 02:55 PM
adconti's Avatar
adconti
I used to live near Cleveland. Maybe the car just assumes its still 30 degrees colder because that's the way Cleveland usually is, or will be again soon.
Old Mar 3, 2008 | 03:11 PM
tls630's Avatar
tls630
Mine did the same last week. I read the manual and took it out for a ride and it corrected itself!
Old Mar 3, 2008 | 05:23 PM
mrtoner's Avatar
mrtoner
The other thing to remember is that if you happen to drive through some standing water and get some on the sensor, it will not read correctly until the water shakes off or dries.....
happy motoring....
Old Mar 3, 2008 | 08:22 PM
traindude's Avatar
traindude
Curious --- Does anyone know where the outside temp thermometer/sensor is located on a C6?
Old Mar 3, 2008 | 09:10 PM
Vette_DD's Avatar
Vette_DD
Real men don't read the instructions.
Front of the radiator.
Old Mar 3, 2008 | 09:37 PM
Marc V.'s Avatar
Marc V.
[QUOTE=JimTN;1564377942]Real men don't read the instructions.
We just post them on the forum
Old Mar 4, 2008 | 02:59 AM
traindude's Avatar
traindude
Thanks for the info!
To Help!Outside temp reading wrong
