Stupid question??
Mar 8, 2008 | 10:48 AM
Stupid question??
I just bought new 08 rims for my 06 and are going to change out my rims shortly. Are the tire pressure sensors transferrable? They sent me new O-rings with the new rims. Are these for the sensors?
Mar 8, 2008 | 11:55 AM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Not a stupid question, and yes, you should transfer the sensors. A tire shop that knows Corvettes will have no problem with this.
Mar 8, 2008 | 12:15 PM
Just make sure that they put them on the same corners as the old wheels.
Mar 8, 2008 | 12:23 PM
Yes, the sensors are transferable and it is standard practice to replace the sensor seals. A good shop will also "location mark" (LF,RF, ect.) the sensors to avoid having to reset them.
BJK
Mar 8, 2008 | 12:24 PM
Quote:
Originally Posted by
timd38
This will save you the task of "retraining" the sensors.
Mar 8, 2008 | 12:41 PM
07MontRedcp
BJK
What happens when the tires are rotated? I assume they do a left/right swap even though no front/rear can be done.
Steve
Mar 8, 2008 | 01:10 PM
speedy_steve
Steve
Nope. The tires are directional, so you can't rotate them. They are dedicated to the corner they were installed on.
Mar 8, 2008 | 01:15 PM
speedy_steve
Steve
If you can't figure that one out I can see why you're confused.
BJK
Mar 8, 2008 | 01:23 PM
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
07MontRedcp
BJK
Mar 8, 2008 | 03:17 PM
07MontRedcp
BJK
I don't have my car yet, BJK, hence the question. Thanks for your help, though...
Steve
Mar 8, 2008 | 03:54 PM
There is no rotating. There's only fronts, left and right, rears left and right. IMHO, you cannot swap from one side to the other.
Mar 8, 2008 | 04:03 PM
carnut08
Mar 8, 2008 | 04:38 PM
Where are the sensors located?
Mar 8, 2008 | 04:43 PM
Fire69Ice
They are part of the valve stem.
Mar 8, 2008 | 04:47 PM
I have been contemplating new wheels and was thinking about the sensors just today, as usual this site is unreal.
Mar 8, 2008 | 04:48 PM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
carnut08
Sure you can. You just have to have the tires removed from the rim and switched to the other rim of the same size. It's a pita, but it can be done.
Mar 8, 2008 | 04:53 PM
NCM Lifetime Member
JJC1
You think it's unreal now ? Just try it after a fifth of Cuervo.
Mar 8, 2008 | 06:50 PM
Mar 8, 2008 | 07:30 PM
MikeyTX
Well sure, that's possible but the cost would be more than the benefit. I don't know anybody that has ever done it.
Mar 8, 2008 | 09:10 PM
NCM Lifetime Member
carnut08
I had it done to equalize the wear on the inside shoulders of the run flats. Only cost me $100 including the balance. By doing so, I got an extra 5,000 miles of use from the O E tires.
