Dead battery
Old Mar 11, 2008 | 07:01 PM
slvr 07's Avatar
slvr 07
Originally Posted by chet b
Battery tender plus
i have had my bt plus attached since end of november, i started my vert up. yesterday and it started right up. no problem, im glad i had my bt plus
Old Mar 11, 2008 | 08:17 PM
jdoria's Avatar
jdoria
Thanks for the info.
Old Mar 11, 2008 | 08:21 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by antt
How do you route the 120VAC cord to the charger? I like the lighter plug arrangment, but I can't find a way to route the 120VAC supply without leaving the window partially down.
Thanks!
Same as hogs. I leave the window cracked open, cord over the top of the window.
I cover the cord draping down the side of the car with a wrapped towel around the cord.
I then put on the car cover which fits loosely over the entire car. (I bought a "generic" car cover, meaning, it is not form-fitting. Works fine for me indoors, plus it's thick enough to stop me from worrying about "dings." And at $38, a huge "savings." )
Old Mar 11, 2008 | 08:26 PM
maxp's Avatar
maxp
if you look at your door sill you will see a 'v' indentation, the cord will fit in that notch and the door can be closed - window up. try it the next time you check your c6
Old Mar 11, 2008 | 11:13 PM
carnut08's Avatar
carnut08
Yup. That works!
