Adding Navigation?
Old Mar 13, 2008 | 07:41 PM
rockstarZ06's Avatar
rockstarZ06
Default Adding Navigation?
My buddy is getting ready to buy a 05 vert. I has everything he wants except navi. I cant seem to find a straight answer in my searches.
Does anyone know for sure or have done it?
Old Mar 13, 2008 | 07:46 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Yes it can be done. Yes it has been done by members here on the forum. The readers digest version is that he will need a Nav head unit and antenna. The install of the head unit is fairly straightfoward as I have read. He will need to install the antenna. The factory location is under the center of the dash pad ( near the center speaker grille.) It is a bear to install as the center ductwork for the climate control is there. Others have simply affixed it to the dash in a corner. If the car has a HUD it will integrate with the the wiring harness for the HUD.
Once it is installed it will require a trip to the dealer to have the Nav unit matched to the car and disable the theftlock. It is a simple procedure (probably in and out in 20 minutes) with the Tech II.
