Greaseable Outer Ends
Old Apr 5, 2008 | 07:48 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Default Greaseable Outer Ends
I was checking out Ed's site after sending for the CF decals and noticed that he mentioned on the Z51 option they have greasable outer ends on both of the rear toe-links. I do not have the Z51 option BUT I have the greasable rear toe-links. Is that normal?? I am asking for help here because my local dealer doesn't have a clue. Thanks
Old Apr 5, 2008 | 07:50 AM
NEV3R L8's Avatar
NEV3R L8
Sounds wierd. As far as I knew only the Z51 had those but I guess I could be wrong. Maybe the factory gave you a freebie lol.
Old Apr 5, 2008 | 08:00 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Factory freebie. The Z51 car comes with the grease zerks for the end links.
Old Apr 5, 2008 | 08:06 AM
obxchartercaptain
Thats nice....a factory freebie.....NOW what is the difference between the greaseable ones and the NON greasable besides having to grease them every now n then?? Did I in fact get the Z51 suspension??
Old Apr 5, 2008 | 08:22 AM
talon90's Avatar
talon90
NCM Ambassador
The standard end links are simply sealed units that don't require maintenance or additional lubrication. The Z51 end links are expected to be used on cars that are on the track or at autocross events and will be used under more severe driving. They are set-up to prevent pre-mature wear by lubricaiton. They perform the same function.
No, I don't think that you got the Z51 suspension
Old Apr 5, 2008 | 08:57 AM
MannyS's Avatar
MannyS
08 Z51 no longer has grease zerks. If you have the zerk fittings, do not use Mobil 1 grease on these these fittings. You will have a constant drip of thinned out red grease on your garage floor out of the grease zerk.
Old Apr 5, 2008 | 09:17 AM
talon90's Avatar
talon90
NCM Ambassador
Hmm, I didn't know that.
Old Apr 5, 2008 | 10:09 AM
rdodson's Avatar
rdodson
Some day I'll have to check it on my 08 Z51....I've owned the car since October and it has been sitting in garage covered for the past 38 miles on the odometer.....
Old Apr 5, 2008 | 10:48 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
I also was not aware of this. In fact, it was my impression that the F55 also started getting zerks in 08. Having an 07 z51, I can't quickly check.
Old Apr 6, 2008 | 11:40 AM
ATC399's Avatar
ATC399
Hmmmm...Well when I changed my oil a few months back (08Z51) I greased the fittings...I better check my VIN the dealer could've sold me an 07...
Old Apr 6, 2008 | 11:46 AM
Mike's LS3's Avatar
Mike's LS3
Incorrect, my 08 Z51 along with other 08's I have seen have them. If you track the car, GM recommends greasing them after each track event. Otherwise, once a year is fine.
2008 Coupe
Crystal Red / Cashmere
2LT
6 speed
Z51
NPP
Old Apr 6, 2008 | 02:35 PM
Norm66's Avatar
Norm66
Veteran: Marine Corps
St. Jude Donor '08-'09-'10
2008 Coupe
2LT
6 speed
Z51
NPP
I picked up my 2008 on 1/31. It has the grease fittings.
Old Apr 6, 2008 | 02:46 PM
Modshack's Avatar
Modshack
Not necessarily...others here with '08 Z51 suspension have reported NO zerks...
Old Apr 6, 2008 | 02:58 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
My o8 Z51 has zerks. This came up before and I have to wonder what's going on? Some do some don't? Doesn't make sense.
Old Nov 5, 2009 | 10:48 PM
Bat Man's Avatar
Bat Man
Anyone figure this out?
Old Nov 6, 2009 | 12:08 AM
haljensen's Avatar
haljensen
My guess is that all '08 Z51 'Vettes have the rear zerk fittings. Some owners just can't find them. Some don't know what they're looking for and some don't know where to look.
From previous posts;
Some owners believe all C6 'Vettes are Z51.
Some believe all C6 runflats are Supercars.
Some believe that chromed wheels weigh more than painted.
And some actually believe that if it's posted on the Forum it's true.
Old Nov 6, 2009 | 07:25 AM
Swiftrider08's Avatar
Swiftrider08
Wonder if he just means that he removed the grease zerks and installed a plug to prevent the grease drips he mentioned?
To Greaseable Outer Ends
Old Nov 6, 2009 | 08:02 AM
Justasheet's Avatar
Justasheet
My 2005 Z51 does not have Zerk fittings on the toe links. Dealer said they must have been replaced with one that doesn't have them. Was told that all of the toe links he had did not have Zerk fittings.
I will gladly post pics for any non-believers.
Old Nov 6, 2009 | 08:27 AM
kenrobb's Avatar
kenrobb
My 07 w/ F55 had fittings. My 09 w/ F55 does not have them. GM dropped them somewhere along the year. Early F55 had them.
Old Nov 6, 2009 | 09:09 AM
JoesC5's Avatar
JoesC5
Acccording to my 09 owners manual, cars equipped with Z51, Z06 and ZR1 come with the zerk fitting and require greasing. This is a carry over from previous years owners manuals. My 09 Z06 has the zerk fittings, just as the manual states.
