A quick question about the active handling settings
Old 04-08-2008, 08:09 PM
AHTTG
AHTTG's Avatar
Default A quick question about the active handling settings
First of all, I think active handling/traction control are great. Make me look great on the road.
My question is this. When I go to turn the system off a message pops up on the display to let me know which mode I'm in. I'm sure you all know this. The problem is, it won't go away. I have an A6 transmission, so when I'm in manual mode with traction controls off... I'd like to see what gear I'm in Instead all I get is the message that traction control is off. I can still shift with the paddles and everything, but it won't show me what gear I'm in like it normally would. Put the car back in drive, then back in manual mode and that doesn't reset it either.
So how long do I have to wait for the message to go away? Can I configure the settings or something for the display to go back to normal after 5 seconds or so? I'm sure there's something simple I'm overlooking here...
Old 04-08-2008, 08:15 PM
Miaugi
Miaugi's Avatar
Push the "Reset" button, that should clear the message without changing the setting.
Old 04-08-2008, 08:52 PM
Ron H
Ron H's Avatar
I thought I had the same issue when I checked. Then realized mine is in the HUD .
To A quick question about the active handling settings
Quick Reply: A quick question about the active handling settings
