Alignment advice
Old Apr 21, 2008 | 07:32 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by eboggs_jkvl
Set the camber to -0.10 +/- 0.0 F&R if you want long tire life.
Set the camber to -0.45 +/- 0.0 F&R if you want the car for the twisties.
Do not let them get it "within" allowable +/- range. Get it "SPOT ON".
Elmer
Old Apr 21, 2008 | 11:21 AM
Modshack's Avatar
Modshack
Originally Posted by dzhang
Wondering the same. Do these figures change depending on the year ofthe vette? Thanks!
No...
Old Apr 21, 2008 | 11:36 AM
torquetube's Avatar
torquetube
So I'm looking to take my vette in for an alignment. Where should I take it? Are places like Pep Boys ok?
And anything I should know that is specific to the vette?
Thanks for the help!
Go to Roger Kraus Racing in Castro Valley. They do work for lots of racers (truly picky customers) and they happen to specialize in Corvettes.
Old Apr 22, 2008 | 01:22 PM
coolcat's Avatar
coolcat
Originally Posted by Modshack
No...
Are these the factory alignment specs?
Old Apr 22, 2008 | 02:25 PM
CodyC6's Avatar
CodyC6
I hope not, the factory alignment makes your car pull to the right, and ruins the inside edge of your front tires
Old Apr 22, 2008 | 03:59 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Yes those are the factory settings. So, the camber that was recommended will give you the longest mileage on the tires. The stock camber settings are prone to causing uneven wear on the inside 1/3 of the tires. The stock settings will give better performance in auto cross or pylon crushing but will not be the best setting for long highway runs. My camber is -0.10 and I do city driving and highway. Were I to want to do competitive motocross, I would go with the -0.45 camber or higher. The Z is -1.00 front and -1.25 rear on the camber and that is really aggressive for road racing.
Old Apr 22, 2008 | 04:08 PM
supervette26's Avatar
supervette26
anywhere good to go in the Los Angeles area???
Old Apr 22, 2008 | 05:35 PM
Quick 06's Avatar
Quick 06
I just went through this flap with both of my front tires worn out on the inside edges after 14K. My camber was -.9 and .7 respectively (left/right) with the left being slightly more to allow for highway center crowning. So at least on my car, putting the camber close to -1.0 was a mess.
After changing out the tires yesterday I had the alignment set as follows:
Left Front: Camber -.4, Caster 8.0, Toe .05
Right Front: Camber -.4, Caster 7.8, Toe .04
Hopefully it will help with the inside tire wear. I track my car from time to time so will see if there is any appreciable difference with the Camber reduced..
Old Apr 22, 2008 | 11:29 PM
Wayne Enterprises's Avatar
Wayne Enterprises
No...
I assume most places should have these specs right? Or should I bring this in myself?
Thanks!
Old Apr 23, 2008 | 07:40 AM
davekp78's Avatar
davekp78
If you just give them this info you may get an alignment that still causes premature wear. The tolerances are too great. You need to tell then exactly what you want. Why do some people not understand this?
Old Dec 27, 2008 | 10:17 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by carpe dm
I want to decrease/remove some of the negative camber in my front tires, but am having a hard time finding anyone to do it. They are afraid of going "out-of-spec", liability issues! My dealer said I would have to sign a legal waiver and that it would void my warrantee........
Void your warranty on what? the tires? They are a wear item anyway. A decrease in negative camber will only increase the wear life of the front tires.
Old Dec 27, 2008 | 10:21 PM
TEXHAWK0's Avatar
TEXHAWK0
I decreased my camber in 1/8 degree increments until I got acceptable inside tire wear, and I had to get down to -1/8 deg or less. Original factory setting was -1.2 degrees and I was seeing inside tire wear in less than 1,000 miles.
Old Dec 27, 2008 | 10:33 PM
  #33
shopdog's Avatar
shopdog
Elmer I noticed that your camber settings are slightly higher (-0.10 instead of -0.1) in this post compared to another post of yours from last year. Why?
Huh?
-0.1 = -0.10 = -0.100 = -0.1000000000000000000000...
The number of zeros after the last significant figure following the decimal point doesn't change the value.
Old Dec 28, 2008 | 12:52 AM
  #34
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
After wearing out front tires twice on my 06 Z51, I took it in for alignment and all four corners were a mess. Some of the specs were way off. I finally ended up setting the specs similar to yours
Camber LF -.4 RF -.5 (range -1.0 to .1) RF was worst wear at -.9
Caster LF 7.6 RF 7.6 (range 7.3 to 8.5)
Toe LF .04 RF .05 (range -.05 to .15) Were -.07 and -.05
The rears were worse with the RR camber at -1.1 and toe at -.23 and -.21 (range -.10 to .10) Changed these to .05
As you can see, some of these specs were way out of line. The worst was the rear total toe at -.43 and was changed to .11
At the cost of these tires I couldn't keep letting them wear out so soon---especially the fronts on the inside.
Hope this helps.
Old Dec 28, 2008 | 11:20 AM
  #35
eboggs_jkvl
Moderator emeritus
OK, Camber is the issue that is giving the uneven wear. Think about it. If you had a solid rear axle, like my 98 Camaro, what is the Camber? 0 would be my guess. Does that cause issues on cornering? Probably not as good as a tire with a camber of -1.0 as the -1.0 would give a better "foot print" with the tire in a hard turn. 0 camber keeps the tire flat and gives even wear across the entire tire surface for highway touring. So, the -.45 on the C6 has a +/- of .60(per the chart). What the heck does that mean? That means you can have a reading of +.25 to -1.05 and still be within limits as acceptable for proper camber settings on the C6. Well, big whoop! Just eyeball it in and drive right?
The longest mileage from your tires, in terms of camber, would be the flattest you can get the tires on the road. A camber of 0.0 would be flat. Because of the 4 wheel independent suspension, I don't think 0.0 is good for the car, thus my recommendation of -0.1 +/-0 No plus or minus allowed. Get it to -0.1 and that's it. DO that to all 4 wheels and your uneven tire wear is GREATLY reduced.
"I want to race!", you say? Ok, crank up the camber to -1.0 OR HIGHER for road racing. The camber will help in the turns. If you are racing, tires will get worn out very quickly. That is some of the costs of racing. Tires, brakes, brake fluid and such are used up quickly.
Toe will cause uneven wear to the inside or outside of the tire if the toe is too big. A toe of 0 would have the tires running perfectly straight and not scrubbing off rubber as you drive straight down the highway. 0 toe can be "darty" and not give a solid feel to handling so a little positive toe is dialed in to firm up the feel. so set the front toe to .1 and the rear to to 0 for the best setting. DO NOT allow the +/- crap here either!! The chart says +/-.2 Don't allow ANY +/-
Ok, off the soap box now. I hope I didn't muddle any of that up.
Elmer
Old Dec 28, 2008 | 12:11 PM
  #36
cmonkey713's Avatar
cmonkey713
You really need to do a four-wheel alingment. If you want a little more even tire wear take some of the negative camber out of the front.
some here say no more than .25 of neg. camber. If the car is lowered you should also get a four wheel adjustment. this should cost you about $100.00 or so at a good tire shop. Sometimes certian tire shops have problems with getting Corvettes up on their alignment machines, be sure and ask them if they regularly do Corvettes. There should be quite a few posts on this subject, just use the search function to read all about it.
Old Dec 28, 2008 | 12:57 PM
  #37
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Just had alignment done on a C6 I bought a few weeks ago. The previous owner had lowered it about an inch and I noticed when backing up, the front tires would slip when the wheel was over (not hard over but over). Took it to a well known tire place and they found toe-in (F& R) was off so they adjusted it.
Now when I am going slow and make a 90 degree turn (like turning into a parking stall), the front tires really scuff and slip. I'm taking it back to them tomorrow with the figures from this thread and see what they do
To Alignment advice
Old Dec 28, 2008 | 03:49 PM
  #38
Modshack's Avatar
Modshack
That really has more to do with the designed suspension geometry than the alignment. My alignment is spot on and does that too. Seems to be a consequence of wide tires. .. Don't worry about it.
Old Dec 28, 2008 | 04:05 PM
  #39
K9KUZ's Avatar
K9KUZ
It sure does, and I found out at 13K. Took it to a shop that does race cars (and TireRack people) to fix things.
Here's a thread with some good info:
http://forums.corvetteforum.com/c6-c...er-sez-no.html
Old Dec 28, 2008 | 06:08 PM
  #40
KenHorse's Avatar
KenHorse
Thing is.. my C5Z06 doesn't do that. Sure I know it has 17" front tires not 18" like the C6 but still.....
