VIN question
Old Apr 20, 2008 | 02:05 PM
danbo56's Avatar
danbo56
Default VIN question
Question:
Can you tell from a VIN the date of manufactuer? Or can it only be summised by when in the production run is was built?
This is the vin: 1G1YY26E675114598
thx
dan
Old Apr 20, 2008 | 02:33 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
By the sheer vin #, I would guess that your car was built around November. Since there are usually about 3000 Corvettes produced each year starting in July, you can usually divide your VIN by 3000 and use that number as the production month with the counting of months starting in July.
By far an even better, much more accurate method would be to look at the sticker on your driver's door. It actually shows what month your car was produced.
You can contact the National Corvette Museum and order the window sticker and build sheet for your car. It will show everything about your particular car including build date, etc.
Sanford in Saraland, Alabama
Old Apr 20, 2008 | 02:46 PM
danbo56's Avatar
danbo56
Tanks!!
Old Apr 20, 2008 | 05:21 PM
haljensen's Avatar
haljensen
Your car is number 14,598 of the '07 production. Probably Dec. of '06? Check the drivers side door jamb, a sticker gives the month and year of production.
Old Apr 20, 2008 | 06:55 PM
Vette_DD's Avatar
Vette_DD
Send a PM to GMautotech with the VIN, your email address, and what you want (birth date) and he'll fix you up.
Here's a link to his profile.
http://forums.corvetteforum.com/member.php?u=221526
Old Apr 20, 2008 | 07:00 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Originally Posted by danbo56
Question:
thx
dan
So its a Z06.
Old Apr 20, 2008 | 07:59 PM
karguy6's Avatar
karguy6
Question:
thx
dan
VIN 1G1YY26E675114598
VEHICLE BUILD
Merchandising Model : 1YY87 -2007 CORVETTE Z06 2 DOOR
Gross Vehicle Weight Rating : 1622 kg (3577 lb) Order Number : KMDZ24
Build Date : 10/26/2006 Build Plant : 175Y
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AAB - MEMORY PACKAGE AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AQ9 - ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS
BGR - BOWLING GREEN PLANT BS1 - INSULATION ACOUSTICAL PKG
CJ2 - DUAL ZONE, ELECTRONIC A/C DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV D42 - LUGGAGE SHADE & PARCEL NET
FE4 - Z06 SUSPENSION FE9 - 50-STATE EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT J56 - BRAKE SYSTEM POWER
KA1 - HEATED SEATS K63 - 110 AMP GENERATOR
LS7 - ENGINE, 7.0 LITER 505 HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - TRANSMISSION, 6-SPEED MANUAL NK4 - LEATHER WRAPPED STEERING WHEEL
NT7 - EMISSION SYSTEM FEDERAL TIER 2 N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QL9 - Z06 POLISHED ALUMINUM WHEELS R6K
R6P - SPECIAL PAINT R9N - TWO-TONE SEATS WITH EMBROIDERY
SLM - STOCK ORDERS UG1 - UNIVERSAL HOME REMOTE
UJ9 - LOW TIRE PRESS. INDICATOR UK3 - STEERING WHEEL CONTROLS
US3 - ANTENNA DIVERSITY U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U3U - AM/FM STEREO, CD PLAYER, DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES (REPLACES 6-DISC IN DASH CD W/SINGLE DISC CD) U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VDD - VEHICLE INFORMATION DVD
VK3 - FRONT LICENSE PLATE BRACKET V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFA - FRONT TIRE - P275/35ZR18 YFJ - TIRE REAR P325/30ZR19
1SZ - PREFERRED EQUIPMENT SAVINGS 19U - LEMANS BLUE METALLIC
2LZ - 2LZ PREFERRED EQUIPMENT GROUP AM/FM STEREO, 6 DISC CD CHANGER, MP3 PLAYER, BOSE PREMIUM 7 SPEAKER SYSTEM, XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING WHEEL HEATED SEATS INSIDE REARVIEW MIRROR, AUTO DIMMING, COMPASS DRIVER MIRROR, WITH AUTO DIMMING MEMORY PACKAGE UNIVERSAL HOME REMOTE SIDE IMPACT AIRBAGS, DRIVER AND PASSENGER LUGGAGE SHADE & PARCEL NET STEERING WHEEL RADIO CONTROLS ENHANCED ACOUSTIC PACKAGE 84I - INTERIOR TRIM TITANIUM
843 - TITANIUM GRAY
Old Apr 20, 2008 | 08:16 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Here's another would love to know the particular's
1G1YY36W785119180 Thanks
Old Apr 20, 2008 | 08:31 PM
karguy6's Avatar
karguy6
VIN 1G1YY36W785119180
VEHICLE BUILD
Merchandising Model : 1YY67 -2008 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1712 kg (3775 lb) Order Number : MJZQ74
Build Date : 01/15/2008 Build Plant : 185Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - 6 WAY POWER PASSENGER SEAT
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AQ9 - ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS BGR - BOWLING GREEN PLANT
CJ2 - DUAL ZONE, ELECTRONIC A/C CM7 - POWER CONVERTIBLE TOP
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR DD8 - OSRV
FE2 - SUSPENSION SYSTEM RIDE, HANDLING FE9 - FEDERAL EMISSIONS
F55 - MAGNETIC SELECTIVE RIDE CONTROL (INCLUDES: DRIVER SELECTABLE TOUR AND SPORT SETTINGS, LARGER CROSS-DRILLED BRAKE ROTORS) GM8 - REAR AXLE 2.56 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JJA - PT DRESS SUBASSEMBLY
J55 - HEAVY DUTY POWER BRAKES KA1 - HEATED SEATS
K63 - 110 AMP GENERATOR LS3 - 6.2 LITER 436 HP ENGINE
MX0 - TRANSMISSION, 6-SPD PADDLE SHIFT AUTOMATIC MYC - 6 SPD AUTO TRANSMISSION
NK4 - TILT LEATHER WRAP STNG WHEEL NPP - DUAL MODE EXHAUST
NT7 - EMISSION SYSTEM FEDERAL TIER 2 N37 - PWR TELESCOPING STEERING WHEEL
QX3 - CHROME ALUMINUM WHEELS R6K - PROCESSING CODE
R9N - PROCESSING CODE - SEAT R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS UE1 - 1 YR ONSTAR SAFE & SOUND(ASK DLR ABOUT TURN-BY-TURN NAV UPGRADE)
UG1 - UNIVERSAL HOME REMOTE UJ9 - LOW TIRE PRESS. INDICATOR
UK3 - STEERING WHEEL CONTROLS US3 - ANTENNA DIVERSITY
UV6 - HEAD-UP DISPLAY U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U3U - AM/FM STEREO, CD PLAYER, DVD NAVIGATION (REPLACES 6 DISC- -IN-DASH CD W/SINGLE DISC CD) U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VA5 - ENGLISH LANGUAGE LABEL
VDD - VEHICLE INFORMATION DVD VH9 - ENVELOPE OWNER INFO MANUAL
VK3 - FRONT LICENSE PLATE BRACKET VT7 - OWNERS MANUAL ENGLISH
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XBH - FRONT TIRE - P245/40ZR18
YPI - REAR TIRE - P285/35ZR19 1SZ - PREFERRED EQUIPMENT SAVINGS
3LT - 3LT PREFERRED EQUIPMENT GROUP AM/FM STEREO, 6 DISC CD CHANGER, MP3 FORMAT, BOSE PREMIUM 7 SPEAKER SYSTEM, (REPLACES STD/OPT/PKG RADIO) HEAD-UP DISPLAY PWR TELESCOPING STEERING WHEEL HEATED SEATS MEMORY PACKAGE UNIVERSAL HOME REMOTE STEERING WHEEL RADIO CONTROLS POWER CONVERTIBLE TOP 31I - LT CASHMERE INTERIOR TRIM
313 - CASHMERE 35T - TOP - BEIGE
41U - BLACK
Old Apr 21, 2008 | 02:53 AM
obxchartercaptain
VEHICLE BUILD
OPTION CODES
41U - BLACK
That's my baby....Thanks Kar Guy
Old Apr 21, 2008 | 12:01 PM
fever_08's Avatar
fever_08
sorry to hijack this thread, but is there anyway you can run this vin for me Kar Guy??
1G1YY26U275115822
Thanks in advance
Old Apr 21, 2008 | 12:13 PM
User 020720's Avatar
User 020720
My VIN sequence is 75118443, not far from this one and mine was built Nov 29, 2006.
Old Apr 21, 2008 | 08:21 PM
fever_08's Avatar
fever_08
Kar Guy, are you around??
Old Apr 21, 2008 | 08:34 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
There are actually approx 40,000 built each year and neither the window sticker or the build sheet will show the date of assembly...
Old Apr 21, 2008 | 08:37 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by Glennm27
There are actually close to 40,000 built each year and neither the window sticker or the build sheet will show the date of assembly...
The build sheet will not show the build date. The build sheet is issued to the car as a set of instructions for the build of the car prior to the car hitting the line. The only place to get the actual build date of the car is via the GM Vehicle Information System (VIS). It is not on the car, it is not in the wheel well in grease pencil. It cannot be found on the window sticker or the build sheet or on the decal in the door jam.
Old Apr 21, 2008 | 08:39 PM
pit-pony's Avatar
pit-pony
I would love to see mine
1G1YY26U175122776
Old Apr 21, 2008 | 10:37 PM
GMautotech's Avatar
GMautotech
1G1YY26U275115822
Thanks in advance
1G1YY26U175122776
Send me a PM with your email addresses
Old Apr 22, 2008 | 12:54 PM
fever_08's Avatar
fever_08
PM sent, thanks !
To VIN question
