That's the challenge. The lower the profile the higher the price. By the time (a) the profile is really low enough, (b) the arm is long enough to reach all the way under the front fascia to the recommended forward lifting point, and (c) the quality is adequate, the price has soared to nearly $500. For a while Sears had a couple of low-cost contenders. Unfortunately after you're through grinding some unwanted vertical tabs off the saddle, a recall notice arrived in the mail. Something about cheap Chinese castings prone to crack. Griot's Garage has a very nice one, but it costs $399 and I'm not sure it meets spec (b). See http://www.griotsgarage.com/product/...o?code=FROOGLE
I've always been partial to Craftsman tools. I use a Craftsman 2 ton aluminum floor jack (slightly modified to better accept the Northern Tool adaptor beams). With the adaptor beam attached I need to drive onto a 2x10 ramp to gain enough clearance but it works great. Craftsman tools are synonymous with quality IMHO.
Check out the ones at Northern tool. I got an aluminum race jack there for $70.
I got the Torin aluminum racing jack (low profile) at Northern. Good value for about $70. It looks like the Craftsman. I don't do any serious under car work so it works well for the simple stuff - oil change and tire work
Check out the Bugman's site, click on "Jack" on the left side...he has pictures and diagrams of where to place the jack etc...how he gets it under the front of the car...great site!
